| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: WRB BRZ
spill gasoline on car paint
For some reason the gas nozzle didn't auto stop when the tank was full so a descent amount of gas spilled out and splashed onto the car and myself. There was nothing at the gas station that i could use to clean up the gas on the paint so i waited until i drove home 10 minutes later. I wiped it off the affected area with car wash soap and water, then put a coat of wax on it. Is that good enough or anything else that i should do? My car is opti-coated, does the gasoline burn off the opti-coat? will the paint fade?
#2 |
Drives: 2013 Scion FR-S Argento
I'd just get is sprayed off as soon as possible. maybe put some sealant/Wax on.
Should be fine though. |
#3 |
Señor Member
Drives: 2013 SSM DZE BRZ
Everything I've heard over the years says that gasoline doesn't harm paint; it only strips wax off the surface. With what you've already done to clean it off I don't think you'll suffer any permanent issues from it. I had the same thing happen at a gas station and simply rinsed the area with water. Water still beads on the area (my car is opti-guarded) so I doubt it did anything to harm the coating with the little amount of time it spent on my car. As long as water still beads on yours where the gasoline made contact I'd say the coating is intact; certainly the paint beneath is OK too.
#4 |
Drives: n/a
most hydrocarbon liquids have a pretty low evaporation temperature (it evaporates quickly) as well so luckily, unlike water, it wont just sit there on the paint. also it being mostly hexane which is non-polar compound... i agree with the folks above. should be okay.
| The Following User Says Thank You to Cameronghanson For This Useful Post: | Squishy86 (04-07-2013) |
#5 |
Drives: WRB BRZ
yea thanks guys. i checked this morning on the paint and it looked to be fine after i put a layer of wax over it.
i agree that gasoline evaporates quickly, but i also noticed that 10 seconds after i spilled gas, even though the liquid evaporated, i still noticed that there's a layer of haze over the paint, that's why i went home and washed that part. |
#6 |
Drives: Dirty
No and No. You're totally fine on both accounts.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit |
| The Following User Says Thank You to David-Fermani.com For This Useful Post: | Greg Nichols (04-07-2013) |
#7 |
Drives: 2013 FR-S Ultramarine
What's left when gasoline evaporates are the heavier oily molecules that make up part of the gas-the more solvent and solvent like molecules (such as the hexane mentioned) have a very low vapor pressure and are gone quickly.
In general, it's the more reactive stuff that evaporates fast when it comes to solvents (Acids etc are another story, but also not in gasoline) so it's actually a boon when it comes to spilling things on your paint-the stuff that has the most ability to harm it is gone the quickest. ![]() Nathan |
#8 |
Bird shit is more toxic to your paint than gas. Always carry a microfiber towel to clean anything off. I also carry a spray wax & sealant in my car for this type.
| Paint Correction, Opti-Coating, Car Wraps, Paint Protection & Tinting - LI Detailers | LI Detailers | Cleaning and Detailing | 1 | 12-27-2012 05:12 PM |
| Companies supplying top-tier gasoline in the USA and Canada | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 10-11-2012 05:40 PM |
| South Western Ontario Gasoline feedback | Demandred7 | CANADA | 34 | 09-14-2012 12:08 AM |
| paint restoration : Subaru WRX - bringing the paint back to life | brianc | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 06-25-2012 02:23 PM |
| Gasoline Direct Injection... | DoogenBurns | Engine, Exhaust, Transmission | 5 | 05-21-2012 03:05 PM |
