Old 10-10-2012, 10:53 AM   #1
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Race Harness with stock seats
So I acquired a 4 Point schroth (Rallye cross) harness the other day from my next-season codriver.... I haven't really spent any time investigating how and where I want to install it to. Anyone else install one yet? How'd you do it?
I'm assuming I'll double up on the 3 point factory buckle bolt on the right side of the driver seat, find a bolt to use on the left side... I'm assuming there is probably something at the top of the rear shelf associated with the child seat restraint system I can connect on to??
This will be used for Stock class autocross... so there really aren't any specific rules for installation beyond "Seat belts (and harnesses if used) must be properly installed with attaching
hardware, in good condition, secure, tight, and in compliance
with Section 3.3.1."
where section 3.3.1 says "3.3.1 Driver Restraints
Seat lap belts are required in all cars, and must be installed in cars with
passive restraint systems that do not include a lap belt. Installation and
the use of shoulder belts or harnesses is strongly recommended, however
non-factory upper body restraints may only be used in open cars,
cars with targa-tops in the open position, or cars with T-tops in the open
position when two conditions are met:
A. The roll structure must meet either the requirements of Appendix C
or the Club Racing General Competition Rules (GCR) 9.4.
B. The top of the roll structure may not be below the top of the driver’s
helmet when the driver is in the normal driving position."
I know the guys at Essex were talking about offering a harness bar, this would probably be a back-up plan in the event I dont have the necessary attachment points on the rear deck. I'm not a big fan, even in autocross of setting up my restraint as a spine compressor.
Sccabrz192 is offline   Reply With Quote
Old 10-10-2012, 11:06 AM   #2
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
We're very far along on our harness bar. The prototype should be back from powder coating today. I may have pics up as soon as later this week or early next week. I'll start a new thread with details on it in the next day or so. It is a very stout design, and I think it will really serve our customers well. My hunch is that they'll be shipping out to customers in about 6 weeks or so. Thanks.
Black Friday 2025 at Essex/AP Racing is 11/10 - 12/5/25!
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following 2 Users Say Thank You to JRitt For This Useful Post:
Scooby South (10-12-2012), Surok (10-10-2012)
Old 10-10-2012, 11:12 AM   #3
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Good to hear from you Jeff! that is great news.
I'm looking forward to seeing the piece... what attachment points did you use for the bar?
Old 10-10-2012, 01:32 PM   #4
xwd
I followed this guy and did the Rallye 3, the Rallye 4 may not work since the rear seats are so close the angle of the straps would be extreme. Might be okay for autocross though. The 3 uses a single attachment point which can be attached to the seat belt reel near the C-pillar. It's at an angle to the seat but that's still an approved way to mount it. You can also mount it to the child seat anchor to make it straight but the belt points are stronger.
http://www.ft86club.com/forums/showthread.php?t=15051
There are a few folks making harness bars now but most are more like rollbars...
Old 10-10-2012, 03:40 PM   #5
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I was going to do the Rallye3 myself. Seems like the most straight forward and would work well for an autocrosser/daily driver car.
TomR
ABQautoxer is offline   Reply With Quote
Old 10-10-2012, 04:00 PM   #6
JRitt
JRitt's Avatar
It's a seriously high quality piece...I think our customers are going to be very pleased with them. We use four mounting points. Our bar has billet aluminum end plates that attach to the B-Pillars on either side. The end plates are bolted to the factory shoulder seat belt mounting points (near the roof, behind your head). The plate extends down the B-Pillar about a foot, and the bar will have four different heights to which it can be adjusted (depending on driver/seat height, etc.). At the bottom of each plate, a rod attaches and runs back to the shoulder belt mounting location for the rear seat. The bar itself runs straight across between the end plates and B-Pillars...no goofy bends, curves, or other things to weaken the structure.
Our piece was not designed for quick removal or style. It is designed for effectiveness, function, stability, stiffness, and low weight.
www.essexparts.com
Old 10-10-2012, 05:56 PM   #7
gmookher
price is secondary when it comes to safety
would love to see pics
Old 10-10-2012, 07:43 PM   #8
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
This.
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 10-12-2012, 10:43 PM   #9
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Sooo I finally took a few minutes to look at the project and I found I actually have a Rallye 4 harness, not a rally cross, so that is nice.
I also took a look at the child seat retention latch on the shelf and bingo. Looks like a nice robust mounting point right in the correct spot, directly behind the driver, about shoulder height. I'll just pop out the child restraint bracket and double up the harness leads on the bolt with the lock washer. Done and Done.
Old 10-12-2012, 11:44 PM   #10
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
PICS Please..
Bill
Scooby South is offline   Reply With Quote
Old 11-21-2012, 02:44 AM   #11
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
sorry for the huge photo, but whats the angle of the top of the seatback on the front seats to this point if we were to use a Rallye 4 and mount the rear connections in these neat slots. as opposed to using a rallye 3 and using the rear seatbelt retractor.
sorry my english is not best.
Surok is offline   Reply With Quote
Old 11-21-2012, 03:27 AM   #12
fatoni
it depends on your goals i think. if you just want more support thats feasible but if saftey is an issue i would advise against uing a harness with a stock seat.
The Following User Says Thank You to fatoni For This Useful Post:
Superhatch (11-21-2012)
Old 11-21-2012, 10:15 AM   #13
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
as per the other thread..
what FIA has to say about this stuff
http://www.ft86club.com/forums/showp...73&postcount=8
Old 11-21-2012, 10:40 AM   #14
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
You can use those attachment points, but I wouldnt do it for anything beyond autocross, that angle is well above the 10 degrees and in the event of a more serious event, can cause spinal compression concerns.
When I get around to my install, I'll post pictures of where I am attaching.
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 02:15 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 04:19 AM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 02:37 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-17-2012 12:41 AM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 09:51 PM
