Old 03-21-2013, 07:35 PM   #1
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Engine Pulley Torque Requirements
I got the GFB Lightweight pulley kit, but it did not come with instructions stating what torque they should be installed to.
What have people installed them to for the 3 pulleys?
JDKane527 is offline   Reply With Quote
Old 03-21-2013, 08:21 PM   #2
jwjknorr
Drives: FRS 2013
Crank is 94 sry i dont know the rest
jwjknorr is offline   Reply With Quote
The Following User Says Thank You to jwjknorr For This Useful Post:
JDKane527 (03-22-2013)
Old 03-22-2013, 03:21 AM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Here you go
http://www.ft86club.com/files/BRZengine.pdf
Im not sure exactly which other two pulleys the GFB replaces but you can simply hold CTRL + F and then type in 'pulley'. Hope you find something
LeeMaster is offline   Reply With Quote
The Following User Says Thank You to LeeMaster For This Useful Post:
Old 03-22-2013, 06:18 AM   #4
JDKane527
JDKane527's Avatar
Thanks for the info, I torqued the crank to 94 and 3 bolts for water pump to 25 before I read the manual you linked haha. The alternator I couldn't remove so I'm going to try taking it to a shop.
Old 03-22-2013, 04:09 PM   #5
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
I got the beatrush pulley set, installed the crack and water pump pulley, anyone know how to remove the OEM alternator pulley?
ahaghshenas is offline   Reply With Quote
Old 03-22-2013, 08:19 PM   #6
LeeMaster
Red wine
There are a few ways you can do this after you remove the belt and the two 10mm bolt holding the cover, you can use a heavy duty glove to hold the pulley and use an impact gun to yank that bolt out, or you can have someone else hold it using heavy duty gloves while you use a breaker bar.
Old 03-22-2013, 08:24 PM   #7
JDKane527
JDKane527's Avatar
Using an impact gun is the easiest way to remove the alternator nut.
I tried removing the alternator and using nonslip drawer liners to hold the pulley in a vice, to prevent damaging it. I used a breaker bar with 24mm socket to try and remove the nut, but it just slipped out. With an impact gun today, took all of 5 minutes.
Alternator pulley torque setting?? ahaghshenas Engine, Exhaust, Transmission 4 07-27-2014 09:03 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 11:52 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 12:44 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 08:45 PM
Minimum requirements... Blokatos Scion FR-S / Toyota 86 GT86 General Forum 528 11-15-2011 05:04 PM
