Southern California SoCal
Old 10-24-2015, 06:45 PM   #1
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
California Smog Check
Has anyone gotten smogged recently?
I heard stuff months back that the smog stations are now just checking your ECU (plugging in a obd2 scanner) for CEL and a visual inspection for OEM components.
Is there still an emissions test?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 10-25-2015, 12:13 AM   #2
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
the smog program did change this year.
what we check is hook up our OBD II scanner to your car. it reads that all monitors are ready and no codes present (pending code OK). then we do a visual inspection to see every component is in place. If the car has any aftermarket parts we need to check the CARB # to make sure that built for that car and input the carb# into the system. if no label found on a aftermarket part we need to fail it.
ExxelDistributions is offline   Reply With Quote
The Following 2 Users Say Thank You to ExxelDistributions For This Useful Post:
LXXXV1 (10-26-2015), Phantobe (10-25-2015)
Old 10-25-2015, 12:16 AM   #3
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Even if its a catback?
jaorocks1 is offline   Reply With Quote
Old 10-25-2015, 12:17 AM   #4
ExxelDistributions
no anything after the secondary cat doesnt matter. you can have straight pipe it wont matter.
Also whatever I explained applies to 2000 and new cars only. All 1999 and older cars we still do the old way with the dyno and exhaust emissions
LXXXV1 (10-26-2015), MisterSheep (10-27-2015)
Old 10-25-2015, 12:34 AM   #5
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Does this mean my e85 tune won't pass? Lol I have to switch back huh... Damnit..
Old 10-25-2015, 12:35 AM   #6
ExxelDistributions
does e85 cause a CEL and a tune covers it? if yes then yes youll have to
Old 10-25-2015, 05:58 PM   #7
Phantobe
Phantobe's Avatar
Thanks for the info bud.
At least with the OFT E85 tune will not cause a CEL.
Reason I asked is because I plan to gut my stock headers, it sounds like I should pass SMOG okay so long that they don't do a sniffer test.
Old 10-25-2015, 07:24 PM   #8
LANI86
Drives: 2015 Scion FR-S
Wait, so catback exhausts are ok right?; considering everything else being OEM??
LANI86 is offline   Reply With Quote
Old 10-25-2015, 07:31 PM   #9
ExxelDistributions
Catback is OK!
The Following 4 Users Say Thank You to ExxelDistributions For This Useful Post:
DandoX (05-10-2021), diegoei (09-20-2016), MisterSheep (10-27-2015), turtlefeeder (09-09-2016)
Old 10-25-2015, 07:37 PM   #10
LANI86
*Deep breath*....Thank you RevolutioN.
The thing is I just bought a new CATBACK exhaust and was just about to install it and came across this thread and scared the crap out of me.
Old 10-25-2015, 07:38 PM   #11
ryoma
ryoma's Avatar
what about catless headers, assuming it passes the visual? if there is a code relating to the cat that comes up, but a tune "hides" it as labeling it unready/not warmed up (or however a tune hides the cat CEL). I know some states only allow around 1 or 2 unready codes before they fail you or tell you to come back later. I am not sure if CA allows that.
Old 10-25-2015, 09:32 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Catless header will pass a sniffer test?
Good luck with that...
86kahl (08-31-2021)
Old 10-25-2015, 09:34 PM   #13
ryoma
ryoma's Avatar
I assumed that it's just the visual and OBD2 scan. I thought the sniffer test/dyno was for the pre-2000 cars?
Old 10-25-2015, 09:39 PM   #14
mav1178
mav1178's Avatar
Entirely depends on where you live. Some counties in CA are completely exempt from smog testing... but people in other parts of the country just hate on CA as a whole.
http://www.smogcheck.ca.gov/pubwebqu...ZipLookup.aspx
http://www.smogcheck.ca.gov/FormsPub...k_Program.html
Map of different smog requirements in California:
http://www.smogcheck.ca.gov/pdf/Program_Map.pdf
SmartedPanda (09-09-2016)
Smog check for out of state people? goshem Southern California 4 09-25-2015 07:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 12:05 PM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-27-2015 12:19 AM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 01:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-20-2014 12:57 AM
