Old 01-25-2013, 02:32 PM   #1
J-Money
J-Money's Avatar
Drives: GT-86
Does 6k HID's Go well With the Turn Signal Switchbacks
As what the title says. I want the Colors to match It looks weird with a yellowish light then i got bluish white turnsignals
J-Money is offline   Reply With Quote
Old 01-25-2013, 02:36 PM   #2
waterbison777
IMO, 6k is hardly blue. More like a super bright white than anything else. You'll only notice the blue if you're looking for it and you're in the know.
waterbison777 is offline   Reply With Quote
Old 01-25-2013, 02:46 PM   #3
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Here is my 6k and 5k.. Remember some cameras pick up the blue more then others and some manufactures have different colors all together
My 5k retrofit and switch backs
Gixxersixxerman is offline   Reply With Quote
Old 01-25-2013, 02:48 PM   #4
J-Money
J-Money's Avatar
Drives: GT-86
Does the 6k match the switchbacks
Old 01-25-2013, 02:52 PM   #5
Gixxersixxerman
Close enough.. Again.. Some manufacter colors are off to others.. Brand A 6k might be closer to brand B 5k or vise versa.. I couldn't see as good with 6k.. That's why I went to 5k.. But the DDM 6k is close to the color of my switch backs..
That 5k I have is just about pure white.. It's morimoto from the retrofit source.. The DDM is a slight blueish
Old 01-25-2013, 03:35 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
mine match close enough (see display picture or my modification journal link in sig)
The Following User Says Thank You to SkAsphalt For This Useful Post:
TheGuyWithTheFireStorm (01-25-2013)
Old 01-25-2013, 03:59 PM   #7
StRacngtC06
StRacngtC06's Avatar
Drives: 2013 Whiteout FR-S
Mine match pretty close...
Sent from my SPH-L710 using Tapatalk 2
StRacngtC06 is offline   Reply With Quote
Old 01-25-2013, 04:32 PM   #8
J-Money
J-Money's Avatar
Drives: GT-86
Can you see farther with the 6k?
Old 01-25-2013, 04:46 PM   #9
Gixxersixxerman
http://www.hidplanet.com/forums/show...bout-HID-bulbs
A ton of good info there.. And through out that site.. I think this is the article about how the lumens change with temp of the bulb.. And that while some people can't tell a difference with 400 lumen difference.. Others could.. For me.. I lost depth when I was running 6k... BUT it was also in the factory projector.. I hated it.. I couldn't see at all.. And my commute at the time was one way in the middle of the desert at night.. I couldn't run high beams because its the only road in and out of post.. So I went with the retrofit and its worth every single penny.. It really is.. It looks like I can see for ever now and with the sharp cut off not blinding a soul.. Good thing is.. Bulbs them selfs are pretty cheap.. So buy your 6k kit.. Then pick up another temp like 5k or 4300 and see what you like best..
Old 01-25-2013, 04:50 PM   #10
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I have 5K & switchbacks. Matches perfectly.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
The Following User Says Thank You to Tim_Asphalt_FRS For This Useful Post:
SkAsphalt (01-25-2013)
Old 01-25-2013, 05:02 PM   #11
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
no, 4300k or 5000 (depending on bulb maker) are the ideal k temperature for distance and light output. 5000+ just goes bluer and into purple/pink the higher you go
Old 01-25-2013, 10:33 PM   #12
Yosty
Drives: 2013 Scion Frs
ok i really need halp im looking for some simple upgrade lights.
i want the 6k or 5k lights
as well as the switchbacks turn signals... here is the catch
i am looking for simple install meaning i dont really want to run more wires threw the car or drill anything into the lights....
please help me with parts and were to get them ... PM me if you can help
Yosty is offline   Reply With Quote
Old 01-28-2013, 09:05 AM   #13
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
HID drop in's just literally get installed where your factory bulbs go in (long debate about drop-ins aside)
Switch backs literally just install where your old turn signal bulbs go in
LED resistor for switch back simply gets plugged in where your old turn signal resistor was
3. very easy steps
as for parts, go to the vendor forums for external/lighting parts and
Old 01-28-2013, 09:13 AM   #14
CaptainSlow
CaptainSlow's Avatar
wtf are switchbacks? I've never heard about this before
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
WTB: stock turn signal relay Cajun Interior Parts (Incl. Lighting) 1 07-23-2013 03:56 AM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:33 PM
