Old 11-28-2012, 01:49 PM   #1
lsr78
Drives: 2013 Scion FR-S MT Ultramarine
AFE Drop In + Perrin Non Resonated Dyno Results
Here is my dyno. 11/28/12 in Arlington, TX at Alamo Autosports. Dynojet dyno. The normal big dip is blank - shop said it seemed like ignition timing cutting out causing the issue. AFE drop in gave 3 hp, Perrin added another 5 hp and 3 ft lbs tq. About what I expected - I didn't do this to gain power. I really like the exhaust note. ECU really learns. They had to do a lot of runs to get it to adapt to the exhaust.
lsr78 is offline   Reply With Quote
Old 11-28-2012, 02:37 PM   #2
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Almost 170 SAE--not bad...
Thx for posting.
GTB/ZR-1 is offline   Reply With Quote
Old 11-29-2012, 12:17 PM   #3
fenton
You might have gained some peak HP but if you look you also lost power when you added the exhaust on the very top end, even compared to stock. Wonder if things were too rich of the ECU is still learning.
fenton is offline   Reply With Quote
Old 11-29-2012, 12:27 PM   #4
2forme
On my car, the ECU learning didn't really affect power. I was within 1-3whp between "learning" runs and "learned" runs. I was kind of hoping for more power from the Perrin, though. I put down 174 with just an SRT exhaust, stock intake and filter.
I was imagining a Perrin exhaust with a turbo kit would be as quiet as stock for a real sleeper, but it looks like it only flows slightly better than stock.
Old 11-29-2012, 12:43 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I wouldn't expect much gains from any exhaust unless the Cat is replaced with High Flow or removed altogether.
Old 11-29-2012, 01:30 PM   #6
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
How much research did you do on the AFE filter? Was there something that made you want it over other drop in filters?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Drop In Filter Dyno Results - FT-86 SpeedFactory FT-86 SpeedFactory Engine, Exhaust, Transmission 241 08-20-2018 12:22 PM
Let there be NO DOUBT: Non Resonated PERRIN> Resonated Perrin HP gmookher Engine, Exhaust, Transmission 78 09-11-2013 11:42 AM
WORKS Resonated AB and Drop in filter phenom86 Engine, Exhaust, Transmission 90 02-28-2013 09:44 PM
WORKS Resonated AB and Drop in filter phenom86 Southern California 21 11-05-2012 01:27 AM
