Old 10-16-2012, 04:52 PM   #1
benlevy3
Drives: FRS
TEIN Flex coilovers with stock wheels?
So special thanks to FT-86 SpeedFactory for all the help (not to mention the great prices).
TEIN's and some rear control arms are on their way.
I am just wondering if I will have any issues with the stock wheels. I was thinking of putting spacers on the stock wheels to push them out a bit, but have been warned about spacers.
Will order some 18" wheels as soon as I figure out what I want.
So, any issues with stock wheels (no spacers) with the TEIN's?
Also, I am assuming that once I get the alignment done, I should be able to adjust height (small adjustments) and camber without needing to redo the alignment.
benlevy3 is offline   Reply With Quote
Old 10-16-2012, 05:24 PM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
There isn't necessarily a problem, but they will be sunken in. With the amount of spacer that would be required to push it out to where it needs to be you're better off saving the money and putting it towards new wheels.
Any time you make setting changes with the suspension you should have it aligned. My recommendation is to purchase the lifetime alignment from Firestone so you can make whatever changes you'd like and not worry about paying again and again for alignments. It'll pay for itself in two trips.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 10-17-2012, 11:44 AM   #3
benlevy3
Drives: FRS
Thanks for the info. Just trying to figure out what wheels and sizes to go with.
At this point (may be different this afternoon), I think I am going to go with 18x8 in the front and 18x8.5 in the rear. Same outside diameter on the tires. About 1.25" drop. Will look to have the wheels flush with the fenders.
anyone know of any good shops to install my Tein Flex adj coilovers in El Paso?? FRS-HHH Southwest 12 10-13-2012 01:58 AM
Tein and Cusco Coilovers In Stock At RallySportDirect.com?!? Of Course!!! RallySport Direct Brakes, Suspension, Chassis 8 10-05-2012 12:39 AM
Tein Flex inside! Silverdub Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-22-2012 04:46 PM
