Old 02-25-2015, 06:10 AM   #1
diodelphi
diodelphi's Avatar
Drives: 86
4350rpm rev cutoff after car crash
i had an accident and two airbag opened plus crashing rear wheel.
now airbag light and abs check light are "on" .
the rev at "P" or "N" do not go over 4350rpm.
i reflashed the ecu but the problem remained.
do you have any idea?
diodelphi is offline   Reply With Quote
Old 02-25-2015, 10:25 PM   #2
De-bounce
Drives: 1
Why are you idling at 4350 RPM?
De-bounce is offline   Reply With Quote
Old 02-26-2015, 01:10 AM   #3
I'd suggest you take your car into the dealer and let them sort things out.
Tcoat (02-26-2015)
Old 02-26-2015, 01:11 AM   #4
Error
Error's Avatar
Drives: FRS
I think he meant he can't go past that RPM when he's in park or in neutral. Don't have the automatic myself, but nothing should be holding him back in revving in neutral, don't know how park works or if it limits revs. My friends Jeep SRT cuts off at around 3 grand in park, as I think most chryslers do. Sorry OP no clue.
Error is offline   Reply With Quote
Old 02-26-2015, 01:35 AM   #5
WesleyG
Drives: 2014 Satin White Pearl GTS auto
I have a feeling that the crash on your rear wheel damaged the ABS sensor, if it was repaired, and the problem assists it was probably not repaired properly.
The Airbag light will stay on until you replace the airbags and reset the code on the Airbag ECU, the same goes for the ABS.
As for the rev limit, could it not be that you car has launch control? 0km/h or mile/hour rev limit?
what software do you have?
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
The Following User Says Thank You to WesleyG For This Useful Post:
diodelphi (02-26-2015)
Old 02-26-2015, 05:46 AM   #6
diodelphi
diodelphi's Avatar
Drives: 86
limp mode
Thanks for help
it seem you are right, the rear abs sensor damaged. we had read dtc codes and three sections has error:
1. airbag (11 dtc error)
2. abs (2 dtc error)
3. speed sensor error
P0500 error
my car is automatic and has no launch control. i did not tested the car at rolling.
Old 02-26-2015, 06:56 AM   #7
steve99
Drives: FT86
Originally Posted by diodelphi View Post
Thanks for help
P0500 error
Rpm limited to 4300 seems very likely due ecu being in limp home mode. The ecu goes into limp home mode for a variety of reasons to save the engine or limit vehicle power and speed if the vehicle stability stsyem or safety systems are malfunctioning.
It likely you will need to replace airbags and speed sensors ect to get the vsc abs and other safety stsyems working before the ecu will come out of limp home mode.
even if dash cluster is malfunctioning you will get limp home mode, i know this from personal experience.
Old 02-26-2015, 07:44 AM   #8
diodelphi
diodelphi's Avatar
Drives: 86
Thanks so
i guess airbag has no effect on limp mode but speed sensor and abs sensor both cause limp mode.
Old 02-26-2015, 07:50 AM   #9
steve99
Drives: FT86
Thanks so
To be honest i do not know exactly which faults cause limp home mode, its possible air bag fault could trigger it as vehicle is unsafe to drive without functioning airbag system.
Old 02-26-2015, 02:07 PM   #10
aagun
Drives: 86
ecu jump to safe engine mod
disconnect one of speed sensor harnesses and test it #
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
rev limiter / fuel cutoff clayrush Engine, Exhaust, Transmission 49 07-26-2017 12:40 AM
A Good Place to Adjust Headlight Cutoff in PDX? Ammunition Northwest 4 02-17-2015 05:56 PM
2014 ORDER CUTOFF & 2015 START-UP DATES botbs BRZ First-Gen (2012+) — General Topics 22 03-12-2014 03:24 AM
Another FR-S Crash. Brndn704 Scion FR-S / Toyota 86 GT86 General Forum 39 01-07-2014 04:22 PM
first 86 crash just86 Scion FR-S / Toyota 86 GT86 General Forum 31 03-12-2012 02:23 PM
