| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Reading codes for TPMS
I am in the process of buying summer wheels and I'm trying to get my TPMS sensors situated. I decided to buy a new set of sensors for the new wheels and I'd like to clone the new set to match my stock wheels so I can just swap wheels without having to re-program anything.
Does anyone in the NJ area (Monmouth\Ocean county) have a ATEQ tool or something similar to read these codes? I am willing to travel to you. I plan to get new sensors from Titan TPMS and have them clone my OEM ones. The ATEQ tool is approx $150 and would only be used once so it'd be (almost) a complete waste. 6 pack of your favorite brew to whoever can help me out. ![]() Thanks! |
#2 |
Discount tire did it for me for free. I swapped wheels with a guy and we didn't swap TPMS's, just wheels. It took them 5 minutes to reset.
#3 |
There's no discount tires near me, but maybe I can use Goodyear or STS. All tire shops should have these readers\programmers, right?
Hopefully a forum member with a reader will chime in. |
#4 |
Drives: 2013 GBS BRZ Limited
Can the techstream software do the TPMS code change?
Just curious. And can Tactrix OP2 work with techstream? Anyone tried it? |
#5 |
I just ordered 4 sensors from eBay Toyota PN PMVC010 which have been confirmed compatible with the BRZ, and the ATEQ Quickset tool from Amazon.
Total spent: 4 Sensors: $46.00 ATEQ Quickset tool: $150.00 I'll post my results once I receive everything an attempt to program them. |
#6 | |
Drives: 2014 BRZ Limited
Hey did this work out for you?? Thanks |
#8 |
Drives: '13 BRZ
So the new sensors can just be cloned to the same as the old sensors? You can just swap summer/winter tires each year without having to reset them every time? Does tire rotation affect anything?
I just bought a set of wheels/tires/sensors from a fellow member and am planning on getting snow tires mounted on them. I want to be able to swap them each year. I thought I had to buy an Ateq Quickset to program them every time I swap them. So you're saying I can just clone them? |
#9 |
If you can get cloned sensors then yes you can just swap wheels with each season with no other action needed. I don't think you can alter the id's of factory sensors if that's what you're thinking... you will need a new set of sensors and you will need the id's from your stock sensors to be cloned.
If you have unique id's for each sensor then you will need a quickest or similar tool. Wheel rotation does not affect anything. Last edited by B-R-Z; 11-03-2014 at 01:44 PM. |
| The Following User Says Thank You to B-R-Z For This Useful Post: | tobin (11-03-2014) |
#10 |
Drives: '13 BRZ
Thanks for the reply. I have two pairs of stock sensors. I just ordered the Quickset and will have the tire shop record the new IDs when they install the tires.
#11 |
Try to emphasize accuracy when they record the id numbers for you, or if you can be there take pictures of each sensor where the id is printed. I misread one of mine and my tpms light came on due to me setting one of the ids wrong onto my ecu. Fortunately I took pictures and was able to take a second look and fix the programming (misread D for 0 or vice versa).
#12 | |
Drives: '13 BRZ
#14 |
Drives: '13 BRZ
Perfect, thanks for the info!
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 09:11 AM |
| Any way to mod the speedo MPH reading? | Tromatic | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-24-2013 11:34 PM |
| Temperature not reading below 0 | BrewCity-FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-22-2013 11:05 AM |
| Reading Vin # | Knightmare | BRZ First-Gen (2012+) — General Topics | 2 | 11-16-2012 02:26 PM |
| ... reading the reviews? | Buggy51 | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 04-26-2012 10:08 AM |
