Old 02-15-2015, 05:46 PM   #1
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Car won't start (EFI ctrl fuse keeps blowing)
Hey all,
In a bit of a rut and running out of ideas. Basically the starter doesn't turn on when I turn my key. I've narrowed it down to the EFI ctrl fuse, which blows every time I replace it and try to start the car. I also removed the EFI Main1 relay and that causes the fuse to not blow. Lights and electronics are all working, it just won't crank.
It happened when I was stuck trying to get the car out of some snow. I accidentally stalled and then the car wouldn't start up. Maybe the snow got in there and shorted something.
Any ideas on how to approach or fix this problem?
Thanks
(New England is getting pounded with snow)
Books is offline   Reply With Quote
Old 02-15-2015, 06:16 PM   #2
steve99
Drives: FT86
heard of this before i tthink
one guy had shorted coil, you could try inplugging all 4 coils then see if fuse blows, if not plug in coils one at a time till fuse blows to islolate crook coil.
other one i remember was short in wiring loom somewhere in engine bay due pinched wires.
your going to need wiring diagram and isolate omponents on that ciruit
if its under warantee go to dealer electrical faults an be difficult to track down.
Books (02-15-2015)
Old 02-16-2015, 10:29 AM   #3
Books
Books's Avatar
No luck with the coils, I'm going to try to dig my car out of all the snow and then try again. Found the wiring diagrams and I'm going to try to figure out where the short is.
Old 08-05-2016, 04:02 AM   #4
JDM_GT86
JDM_GT86's Avatar
Drives: 2013 Scion FRS
Old post but did you ever figure this out? This just happened to my car while driving on the freeway. Had to get it towed back home and found the EFI fuse keeps blowing.
JDM_GT86 is offline   Reply With Quote
Old 08-05-2016, 05:09 PM   #5
Well, I reckon there is a short somewhere .......... (daaaa - me)......just find it.
OR find it the redneck way:
Jump the fuse block with a heavy piece of wire and then look for smoke ........
Wally86 (04-22-2025)
Old 12-08-2020, 11:22 AM   #6
eightyzix
Drives: 2014 gt 86 vt
Smile Same problem
Hey ik this is old but have you been able to narrow down the problem?
I just bought my 2014 86 yesterday and it was in very good condition. The car suddenly wouldnt start in the middle of the night and i got it home now and i have the exact same problem. Will take it to a mechanic, but would give a lot of reassurance if i knew what the problem was.
eightyzix is offline   Reply With Quote
Old 04-21-2025, 11:30 PM   #7
02maher
02maher's Avatar
Drives: Gt86 2013
I have the same problem and I tried unplugging all the sensors that i could (maf-map-camshaft-crankshaft-fuel injector module-throttle body-port injectors) I still have to try to unplug the fuel pump, and the coil packs but last time I unplugged the ECM and it didn't blow this EFI fuse any idea??? BTW my car is supercharged and it died wile I pushed it past 7000 rpms.
02maher is offline   Reply With Quote
Old 04-22-2025, 10:35 AM   #8
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I hope you guys figure this out cus it's kinda crazy
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Is this normal - Hot air blowing in through vents? Lebby83 BRZ First-Gen (2012+) — General Topics 23 05-19-2014 08:58 PM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 06:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 04:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 10:14 PM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 08:10 AM
