#1 | |
Drives: 2014 Subaru Forester
JDL 4-2-1 EL header
![]() ![]() ![]() ![]() ![]() Got an email from JDL today. Exciting stuff! Quote:
https://www.instagram.com/p/BmtLZSAH...on_share_sheet @JDLAutoDesign any more info on this? Last edited by tehShirt; 09-17-2018 at 10:19 PM. Reason: added info |
#3 |
Drives: 2017 BRZ w/PP
whats the price and does it still use stock OP?
#4 |
If it's cheap, it's mine.
| The Following User Says Thank You to gpvecchi For This Useful Post: | chaoskaze (09-14-2018) |
#5 |
Moutain Runner
It's available for purchase. You just need to contact JDL directly.
#6 |
Drives: 2018 BRZ tS
#7 |
Drives: JRSC BRZ SOLD
#8 |
But cheaper than ACE...
#9 |
TRACKBREAD
That's not hard. Even if it's $500 more than the UEL it'll be cheaper than ACE. On a side note, I'd like to see numbers where the car is tuned for each header. If this was on a stock tune for both the UEL would have been at a disadvantage and the difference might actually not be as large. |
#10 |
Drives: 2013 frs red
It says tuned above dyno graph
| The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post: | Trust86 (09-15-2018), Yoshoobaroo (09-15-2018) |
#11 |
Drives: 2016 Halo FRS
I don’t think it will be priced that much higher over the UEL bc of the slip joint connections.
| The Following User Says Thank You to Trust86 For This Useful Post: | Yoshoobaroo (09-15-2018) |
#12 |
Drives: 2017 BRZ
Visually the early merge of the second collector location makes me think it would more closely compete with the Ace A150. The JDL probably needs an overpipe and the Ace includes one so that should be factored into the cost.
| The Following User Says Thank You to gtengr For This Useful Post: | Breadman (09-17-2018) |
#13 |
I am excited for this. I would love to compare this with my tomie uel
2013 Series 10 FRS #553
#14 | |
Everyone forgets this when complaining about it burnt expensive. Price still.stung but it helps a little bit |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 03:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
