Old 06-07-2012, 12:24 PM   #1
serith
serith's Avatar
Drives: 2009 Scion tC RS 5.0
BRZ vs. Snow?
Obviously with how new this car is, no one can say with 100% certainty, but I'm really curious how this car will hold up in the snow. I currently have a similar sized vehicle that I throw 4 steel wheels & snow tires on from November through March. Unfortunately for me, the part of upstate NY I live in regularly receives between 100" to 200" of snow every year -- the worst part is that it starts sticking around thanksgiving and doesn't go away until March. I've never driven a RWD car before (I understand the differences between FWD & RWD though), and I know that the BRZ has a limited slip which will help, but with the weight of the engine over the wheels being absent on this vehicle, how do you guys think it will fair in a snowy climate? It's the one thing that's holding me back from buying this car. I'm on the fence between a BRZ and a WRX. All wheel drive would be killer, but I'm not a huge fan of the styling, the lackluster mileage, or the higher insurance costs. Boost & AWD would be nice, but I'd rather have a BRZ for so many reasons. The BRZ would be a DD for me, so I can't just keep it home when the weather gets ugly. Any thoughts?
09 RS 5.0 -- #862 of 2000 -- 5spd
serith is offline   Reply With Quote
Old 06-07-2012, 12:31 PM   #2
trackmagic
Drives: 1994 BMW 318i
I drive a rear wheel drive 318i in the snow for a few days every year (probally not as much as you have in NY). It has an open diff and it normally is ok if I drive slow. Once I had bald tires and it was a little scary. I think if you had snow tires you would probably be ok. Good excuse to get a second set of wheels?
trackmagic is offline   Reply With Quote
Old 06-07-2012, 12:40 PM   #3
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
I was terrified at first of driving my RX-8 (RWD, limited slip, 50/50 weight - similar to the BRZ) in the snow.
But I've been through 8 winters with it now, with many snowy, 20 mile commutes. As long as you have good snow tires, it's not a big deal as long as the snow isn't too deep for the lower ground clearance.
Both cars also have low torque at low revs, which makes it easier to manage wheelspin.
And if all else fails, Stability Control is there to catch spins (though don't rely on it).
To be honest, some of THE most fun I've had is driving empty, snow-packed roads, lol. It's a chance to *feel* the wonderful balance of a sports car
R8 is offline   Reply With Quote
Old 06-07-2012, 12:42 PM   #4
brzninja
brzninja's Avatar
Drives: 2015 WRB WRX Premium
I'm having the same worries...where I live in PA we either get pounded with snow or have a very light winter. Guess I'll be getting another set of wheels! Though I am glad to hear that others with RWD cars are not having much problems!
2013 Subaru BRZ Limited WRB
brzninja is offline   Reply With Quote
Old 06-07-2012, 12:44 PM   #5
thill
Tires, tires, tires. Buy dedicated snow tires (not all season) and you should be fine. That said there are differences between RWD and FWD in the snow and I would recommend taking the car out in a empty parking lot after the first snowfall and practice. For me (in a manual) I sometimes try to start in 2nd gear, and you have to watch how much power you are applying in turns, etc.
And yeah, make sure you have traction and stability control turned on.
Old 06-07-2012, 12:55 PM   #6
Sovran
Drives: 2013 CBS BRZ-L 6AT
I'm planning to get a set of steelies with snow tires for March-April (give or take). I've driven RWD in ice and light snow before, so I'm not too worried. The AT has the snow mode, too, which should help. As people say, just get some snow tires, experiment somewhere safe, and you should be fine.
What I'm not as sure about is the advisability of adding weight over the rear wheels for the winter. Weight over the drive wheels is good, but I don't want to mess up the dynamics too much. Thoughts?
Sovran is offline   Reply With Quote
Old 06-07-2012, 12:55 PM   #7
RaceR
Drives: 2010 Cooper S, 74 Beetle
Buy the best winter tires for you car.
Drive with all aids on and be safe all the time.
Put all aids off and have fun all the time! :p
It is very easy to learn how to drift in the snow if the conditions are good. Start on a big abandoned parking lot with all aids off...
If im not driving rwd in the winter, it is a a boring winter!
If friends of me, or people in the car community here buy winter cars it is usually one with RWD since their normal car is a boring fwd or awd..
Have fun and drive safe!
RaceR is offline   Reply With Quote
Old 06-07-2012, 12:57 PM   #8
serith
serith's Avatar
Yeah I keep a dedicated set of 4 steel wheels & snow tires on my tC for the winter, and it does okay in the snow. I'm just hoping that the BRZ does as well or better. If it's much worse I'll probably regret buying one, which is what I'm afraid of.
Old 06-07-2012, 12:59 PM   #9
serith
serith's Avatar
No "snow-mode" with the manual? What exactly does it do? I don't want an auto :/
Old 06-07-2012, 01:03 PM   #10
Sovran
If I understand correctly, it just allows the car to start moving in second gear instead of first. If you get the manual, you can do that yourself. It's only an advantage compared to other autos that don't give you the 2nd-gear start option.
The Following User Says Thank You to Sovran For This Useful Post:
Guff (08-28-2012)
Old 06-07-2012, 01:03 PM   #11
Subie
Seρor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
The main thing it does is simply to start-off in second gear. It's totally superfluous with a manual transmission.
Subie is offline   Reply With Quote
Old 06-07-2012, 01:04 PM   #12
brzninja
brzninja's Avatar
Snow mode
To prevent slipping, 1st gear cannot be selected when in snow mode.
Old 06-07-2012, 01:04 PM   #13
BioRage
Drives: ~_~
$1K Snow tires will do the trick.
Or winter storage.
BioRage is offline   Reply With Quote
Old 06-07-2012, 01:15 PM   #14
the_3d_man
Drives: 2007 Legacy GT
I don't understand the whole starting off in 2nd gear thing. I've never had problems starting in 1st. I am perfectly capable of modulating the power on my own and gently starting without slipping in first. Seems like something the older generation always advises.
the_3d_man is offline   Reply With Quote
Snow in the wintertime Double4Free Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 05-30-2012 06:26 PM
Snow tires? smbrm CANADA 12 05-27-2012 02:20 AM
FRS/BRZ in the Snow smbrm Scion FR-S / Toyota 86 GT86 General Forum 38 03-23-2012 08:03 PM
BRZ in snow sieeegel BRZ First-Gen (2012+) — General Topics 40 02-22-2012 01:44 AM
Snow ZetaVI NY / NJ / CT / PA 3 01-21-2012 07:33 PM
