I just want to datalog
I bought a Tactrix Openport 2.0 about 2 weeks ago to fix a p0018 CEL. I flashed my original rom but the light came back. So then I flashed an OFT OTS Stage 1 tune and that fixed the CEL.
Now I would like to datalog and view tunes, etc but Romraider doesn’t work for the BRZ. I tried stand-alone logging with the Tactrix but I don’t think I set it up correctly. So last week I bought the $349 Ecutek kit in the hopes of using that to datalog since there’s no text file to setup or anything. But I know you also have to pay $300 just for a single ECU license, plus another $300+ to upgrade Racerom. That being said I have 2 questions: 1. Is there anything I can use Ecutek for without the license, or did I essentially buy a car with no keys? 2. Can I datalog with Ecutek without flashing my OEM rom back to my ECU? I’m concerned the CEL will return if I do, and I won’t be able to flash the stage 1 tune back until I pay for a license. |
#2 |
Drives: Crapcan
Where you using the right def's with Romraider? That is what a lot of us with OFT or Tactrix use.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (03-17-2023) |
#3 |
Sorry I’m an idiot and worded this incorrectly. I initially used ecuflash to load the OFT tune. I meant to say that logging via Romraider isn’t possible with the BRZ, i had to use the Tactrix/sd card method.
I basically want to know if I can datalog with Ecutek without having to first overwrite my OFT rom with the OEM rom. |
#4 |
The Dictater
Drives: '13 Red Scion FRS
Might be because you used the OFT tune and that messes with the definitions you need. This seems like the same problem you are having?
https://www.ft86club.com/forums/showthread.php?t=141902
Also: "Build Thread" |
| Tags |
| ecutek, logging, tactrix, tuning |
| I Can't Datalog. | ClappedBRZ | Software Tuning | 3 | 03-16-2021 05:39 PM |
| OFT Datalog help | R.Barr | Software Tuning | 4 | 05-08-2020 03:39 AM |
| Can someone take a look of my datalog | sIowbrz | Software Tuning | 24 | 07-14-2016 08:52 PM |
| How to datalog | azynneo | Software Tuning | 0 | 07-06-2016 06:01 PM |
| Will someone please send me a datalog? | ATSAaron | Forced Induction | 48 | 09-10-2013 11:29 PM |
