Old 10-02-2022, 01:08 AM   #1
lenowng
Drives: 2017 GT86
GT86 2017 Daytime Running Light (DRL)
I have just sourced a 2017 GT86 from Japan and read about DRL being illegal there 🤷*♂️
I took a look at the engine compartment fuse box and the DRL relay is missing so is the socket. Wondering if anyone able to hook back up the oem headlight's drl to the car's drl system.
lenowng is offline   Reply With Quote
Old 10-02-2022, 04:29 AM   #2
gpvecchi
gpvecchi's Avatar
DRL are not illegal in Japan, simply they are not mandatory.
The DRL function is hard coded into BCM software, so you need to change it to an EU model, or you can buy a DRL kit from Japan. There are various types, the cheapest is a small harness that feeds the DRL sourcing the power from the headlights height motor.
If you need it, I have a 2019 BCM module for sale, but I'm located in Italy...
Old 10-02-2022, 07:42 AM   #3
lenowng
Drives: 2017 GT86
I see. Does this mean there isn't an easy way to get the DRL system installed? Reading from the car's manual, theres like a feature where the DRL only lights up when the stalk is on 'Off' or 'Auto" plus e-brake is released (for MT)
Old 10-02-2022, 12:09 PM   #4
gpvecchi
gpvecchi's Avatar
I think that's the behaviour of EU cars. I'm sure of the behaviours because I replaced my EU BCM with the JDM one to enable the theft alarm, and the DRL were gone.
The cheapest way is the harness you can find on Rakuten or Yahoo Auction.
Daytime Running Light delete TSB! Memphis Issues | Warranty | Recalls / TSB 256 07-22-2017 11:55 PM
Daytime Running Light options that retain high beams? ELLSSUU Cosmetic Modification (Interior/Exterior/Lighting) 1 10-09-2016 10:29 PM
SCION FR-S LED DRL Daytime running light fog lamp cover GT/86 Cosmetic Modification (Interior/Exterior/Lighting) 12 07-20-2014 09:08 PM
Daytime Running Light Issue AnthonyArcaro Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2014 08:46 PM
Daytime Running Light/ Crystal Vision Ultra Memphis Cosmetic Modification (Interior/Exterior/Lighting) 14 02-08-2014 07:52 PM
