Old 06-14-2013, 04:08 AM   #1
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
obdii port wont work
Everytime I plug a scan tool to my OBDII PORT I get no signal at all! im concerned either the port itself is bad or the ecu. The dealer reads my ecu just fine and doesnt think there is an issue. But all my friends with frs/brz can plug in to theirs and get readings. I keep getting cel codes but cannot read it unless the dealer scans it. This is very frustrating. And I will be making formal complaint to Toyota about this issue with my OBDII port or ecu. Theres obviously some kind of power issue somewhere.
chrisbfrs is offline   Reply With Quote
Old 06-14-2013, 04:22 AM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I know I respond to you in our regional thread about this but because it is becoming more common I'll post it here as well. This is a common issue these cars are having it is not the ecu it is the plug. The dealer had to replace mine when they flashed the ecu to solve the idle dip problem. Thier scanner worked but then they tested the resistance between the pins on the plug they got bad readings. They simply replace the plug it only took a few minutes and they normally have them in stock. They didn't even tell me it was replaced until they were all done working on the car.
Sent from my Q10 using Tapatalk 2
Old 06-14-2013, 06:33 PM   #3
Carwhisperer
Drives: A lot of supercars.
Gotta slightly pull mine towards the steering wheel for it to connect.
Carwhisperer is offline   Reply With Quote
Old 06-14-2013, 06:35 PM   #4
slawdio
ON SALE
Drives: '13 WRB BRZ Premium
does your scan tool work on any other car?
slawdio is offline   Reply With Quote
Old 06-14-2013, 06:36 PM   #5
PANDA86
Old School Status
Drives: .
bad scan tool?....
PANDA86 is offline   Reply With Quote
Old 06-15-2013, 03:12 PM   #6
Dezoris
Dezoris's Avatar
The connector pins on this OBD2 connector are very flimsy. I used the OBD2 MX BT adapter and it stretched out the pins. So when I went to reflash the ECU the port would half work. So, I ordered replacement pins and a different OBD2 connector and re wired it. The stock connector is only sold as a harness and is $800.
So if you are using the stock port be very careful and if you used the obd2 mx it will ruin your port if you take it in and out a few times.
The Following 4 Users Say Thank You to Dezoris For This Useful Post:
Accurate Race Shop (06-15-2013), dchan (06-24-2016), TofuJoe (11-23-2016), ysu (02-22-2017)
Old 06-26-2013, 09:03 PM   #7
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
where did u buy the parts?
diy?
Old 06-26-2013, 10:07 PM   #8
Dezoris
Dezoris's Avatar
Digikey
Here are the part numbers:
WM6653-ND QTY 2
WM3343-ND QTY 2
QTY 20 WM3324CT-ND (ONLY 7 PINS REQUIRED)
You will also need the crimp tool.
In terms of DIY take a picture of factory connector and pins, start cutting one by one and crimp one wire at a time and insert into new connect. When done insert wire holder clip and test.
The Following User Says Thank You to Dezoris For This Useful Post:
phrosty (03-30-2017)
Old 06-26-2013, 10:31 PM   #9
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Digikey
WM6653-ND QTY 2
WM3343-ND QTY 2
Thx
Was this an easy job?
Old 06-26-2013, 10:49 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
Any chance you have the part # form the invoice, or can contact the dealer to get it? The post below seems to indicate you can only get it by buying the full $800 harness.
Old 06-27-2013, 12:47 AM   #11
Accurate Race Shop
Drives: Scion FR-S
They re-pinned mine with parts they had on hand so they didn't put it on the invoice for me but I wish they would have encase something happens I was under the impression they replaced it until I called and found out different. I really hate how these dealerships take liberties with my car.
Old 07-04-2013, 09:37 AM   #12
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Digikey
WM6653-ND QTY 2
WM3343-ND QTY 2
So this is all i need?
Old 07-04-2013, 05:30 PM   #13
Dezoris
Dezoris's Avatar
Originally Posted by whitefrs View Post
Attachment 42990
Yes. Also crimp tool and some zip ties and the new connector wont fit in the clip properly.
Old 07-08-2013, 01:59 PM   #14
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
I have tryd 4 scanners to finally get one to connect idk if its the protocols or sumthing. Its annoying
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 08:17 PM
DIY: OBDII plug relocation solma DIY (Do-It-Yourself) Guides 6 05-30-2013 01:11 AM
OBDII Connector nzer AUSTRALIA 64 05-09-2013 03:44 PM
OBDII (OBD2) Connector nzer Electronics | Audio | NAV | Infotainment 35 04-21-2013 01:36 AM
OBDII iPhone app/adapter phanguy Electronics | Audio | NAV | Infotainment 2 03-12-2013 01:34 PM
