Old 05-08-2023, 11:25 AM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Gearing issues /solutions
So I'm guessing my home track was built around making BRZ transmission builder's profits, trying to get them to sell custom gears.
I originally had a bunch of "bad spots" where I'd bounce off the rev limiter in 3 tgurns.
I *was* able to solve the problem, before the gear change, by going to a 45 series tire, which got me just enough mph (and slower to get there) to solve the problem. However, the difference in lap times was noticeable. Taller gears, more rotating mass further from center and I'm fairly confident the higher CG/less Aero played a role too.
I stepped up with the steeper differential and solved those problems. Now I have them in 3 different turns. Delightful.
I really don't want to go to 45 series sidewall. I also think it may cause a problem in 2 other turns where I just barely justify shifting. Middle ground is new wheels are running a 255 or 265 tire, but I have a feeling it won't be enough to solve the problem (and maybe cause problems on other turns).
My only other solution was bumping up the rev limiter about 250-350rpm, by my rough math. What's the consensus on doing that for engine life and durability? Big deal? NBD? Unknown?
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 05-08-2023, 11:41 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'd be careful, do you have a way of monitoring oil pressure?? The primary issue with increased rev limit is that we're already fighting rapid pressure dropoff at stock rev limit. I don't know the limit for stock valve springs but hopefully someone has input. Honestly, it's not something I'd be terribly worried about if your oil pressure is stable
Old 05-08-2023, 12:14 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd recommended looking at the gearing chart from Jacks and seeing if there is a ratio that will suit you. I know reading 949racings build they went clear down to a 4.67, i'd imagine this gets them up into higher gears with a wider spread to help this issue. If you ask the 949 guys they would probably give you more insight.
https://www.jackstransmissions.com/b...ar-ratio-chart
https://www.ft86club.com/forums/showthread.php?t=131052
Old 05-08-2023, 01:16 PM   #4
GrandSport
GrandSport's Avatar
Yeah, I'm trying to avoid the cost of a custom transmission. At that point, I'd just go sequential.
Old 05-08-2023, 01:39 PM   #5
Code Monkey
Drives: Subaru BRZ
I was running a 7,800 rpm redline on my 2017 for years, zero issues.
Code Monkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Code Monkey For This Useful Post:
autoracer86 (05-08-2023), NoHaveMSG (05-08-2023), RedReplicant (05-08-2023)
Old 05-08-2023, 02:13 PM   #6
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
first I am seeing about jackstransmissions would this make the gt86 transmission "bullet proof" at stock power levels up to say 250-300 from FI ?
I ask because I do see people that continually blow up the stock trans switch to another gearbox all together over doing a custom built one like the one from jacks..
autoracer86 is offline   Reply With Quote
Old 05-08-2023, 02:33 PM   #7
RedReplicant
Drives: None
Probably not. I broke mine making 205whp.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
NoHaveMSG (05-08-2023), villainous_frx (05-08-2023)
Old 05-08-2023, 02:42 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is not exactly what I meant. You need to look at the speed RPM chart and see what may work for you as far as FD gears. I don't recall Blub running custom transmission gears but I could be run.
I was too, then went back down to 7600, now going back to 7800.
Old 05-08-2023, 03:02 PM   #9
RedReplicant
Drives: None
Blub had the MFactory 6th that fixed the big gap between 5-6. Normally it probably wouldn't make sense to do, but with their rear diff ratio they were in 6th at around 120mph or so.
They've still got that transmission for sale
The Following User Says Thank You to RedReplicant For This Useful Post:
Old 05-08-2023, 05:28 PM   #10
autoracer86
Drives: Toyota GT86
Just to double check you broke a jackstransmission making 205whp ? So what is the point of it then ? lol
Old 05-08-2023, 05:35 PM   #11
RedReplicant
Drives: None
Yeah, lol, just a little salty about that.
The collar that replaces the the weak snap ring seems to have come loose, collar wore against the other gear, and let the gear walk... which is what it was meant to prevent in the first place
Old 05-08-2023, 06:08 PM   #12
GrandSport
GrandSport's Avatar
Where is the factory rev limiter? I could have sworn mine came on before 7600. But if Factory is 7600, I think 7800 would get me darn close. At worst, it's a half second before I brake.
Old 05-08-2023, 07:36 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
7450-ish is factory redline.
ineedyourdiddly
Old 05-08-2023, 07:39 PM   #14
CSG Mike
CSG Mike's Avatar
Gearing is always a tradeoff. No car is geared perfectly for every track every corner; every time you change gearing, you gain somewhere to lose elsewhere.
I recommend you short shift to get the gearing you need, or have a soft rev limiter installed that you can ride.
Advice needed with gearing / revs Zero3210 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 01-10-2020 09:44 PM
Solutions for rubbing/melting issues on 2017+ rear bumper deca Engine, Exhaust, Transmission 4 05-14-2019 05:32 PM
New rear gearing and autocross. cab33 Tracking / Autocross / HPDE / Drifting 3 11-07-2017 05:05 PM
Rear gearing AT Lunatic Scion FR-S / Toyota 86 GT86 General Forum 5 01-31-2014 12:27 AM
Transmission syncros/gearing issue Cal3000 Issues | Warranty | Recalls / TSB 6 05-16-2013 11:43 AM
