| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: WRB MT-BRZ LMTD
Cruised in Neutral for 5 miles without loosing speed.
Anyone else noticed that you can pretty much cruise your BRZ into neutral without loosing any speed? I was doing that on a semi flat road and this thing wont stop unless you hit the brakes.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#2 |
Add lightness!
Drives: 17' WRX
I hope my brakes don't fail, I might end up in Soviet Union!
#3 |
That's cool, but driving in neutral is a bad idea. I used to do it, thinking it was more efficient.
You can't respond to a sudden emergency requiring your to shift into gear and apply throttle. Also you don't really save gas. Sent from my Galaxy Nexus using Tapatalk 2 |
#4 | |
When In Doubt...
Drives: Slowww
I agree with all the safety stuff but if you're gonna be coasting for 5 miles, that's better for fuel economy than staying in gear and essentially engine braking. At the same time, the safety part is more important than a few cents saved at the pumps.... Back on topic, I love how this thing cuts through the air so effortlessly. That's what happens when we have a properly designed car with a great CD. Try doing the same thing in a Miata (Miata is 0.32 I think? Not a huge difference but a Miata shouldn't be that high!)
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#5 |
I wasnt trying to save gas, I was trying to come to a stop because of a stop light, so shifted to neutral and then cruised to the stop when it went green and I just continued on. lol still in Neutral.
#6 |
Drives: '13 Premium MT BRZ
you actually use more gas in neutral than you do cruising in gear.
| The Following User Says Thank You to Tomzilla For This Useful Post: | ngabdala (08-10-2012) |
#7 |
Drives: 2008 STi
#8 |
WiKKiD Large Penis
Drives: 2001 Audi TT Quattro "BT 300+Whp"
#9 |
Drives: MT GB BRZ Limited
I'm under the impression you won't be using any gas in 6th since it's running in a vacuum, but I'm not an expert.
I am, however, a smart dude, and I'm tempted to say that this road you were on was probably not flat. Friction and rolling resistance team up to make your car slow down no matter what; a slight downhill will counteract that.
すばらしい。いや、スバルしい。
#10 | |
Duh, its all about Physics. I'm just overemphasizing the car's drag coefficient.
#11 | |
Drives: '03 WRX Wagon, '89 Camry Alltrac
You will use less gas in almost any situation coasting in neutral than in gear. Remember, it takes energy to keep the engine spinning above idle (wasting/using kinetic energy that previously came from gas). Coasting in gear does save your brakes from wear though. ![]() That said, it is safer to keep the car in gear (clutch engaged)... and in many places it is illegal to have the car in neutral while it is moving - not that you will get caught for it. -Charlie |
| The Following User Says Thank You to phattyduck For This Useful Post: | Giccin (08-10-2012) |
#12 | |
Drives: '13 BRZ Lmtd
I thought most laws just forbid turning off your car in neutral when coasting (like a poor man's start-stop) if your vehicle loses boost for brakes or steering in that situation. Anyway, I don't think it's worth it to coast this car in neutral. If you really want to hypermile that way, get a hybrid with start-stop. Last edited by DSPographer; 08-10-2012 at 01:53 PM. |
| The Following User Says Thank You to DSPographer For This Useful Post: | ngabdala (08-10-2012) |
#13 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
Must of had a hell of a tail wind.
So many modders have more cents than sense!
#14 |
Reap the BReeZe
Drives: 04 LandShark STi
I can think of at least one good reason to be coasting in neutral at some point, and that would be for a coast down test to check your aero efficiency. Of course for that, you would want to do it in both directions on the same stretch of road in order to counter any elevation or wind effects.
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
| My car is in and still 1,304 miles away! | joshua | BRZ First-Gen (2012+) — General Topics | 16 | 06-28-2012 08:02 PM |
| 2500 miles | F3dzo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 06-26-2012 09:36 AM |
| Some Miles | White_OUT_FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 06-22-2012 02:00 PM |
| 560 miles later | DantKR | BRZ First-Gen (2012+) — General Topics | 10 | 06-07-2012 06:03 PM |
