Old 04-11-2020, 04:41 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Removal of Balance Weights
Please reply with any tips on clean removal of adhesive fastened lead wheel balancing weights. The tire shop said to just paint over the resultant scratches. Bad solution!
My RS2 wheels are painted black and I hope not to damage the finish while removing the original stick-on weights. Will be having UHP times mounted in place of the OEM Primacys.
Muskoka800 is offline   Reply With Quote
Old 04-11-2020, 05:50 PM   #2
ls1ac
ls1ac's Avatar
Use a solvent and work slowly, plastic tools. It will leave no marks. I use brake cleaner.
edit: next time take the weights off first before going to the tire shop. They like to use a putty knife. Magic marker or black paint stick (auto store) will make you feel better.
The Following User Says Thank You to ls1ac For This Useful Post:
Impureclient (04-11-2020)
Old 04-11-2020, 08:26 PM   #3
Impureclient
Drives: 2015 FR-S
Also, find a shop that cares as much as you do about the car(or at least they act like it)and stick with them.
I have a local place(Tiresplus of all places) that when I first came to them to have tires installed they in pointed out a tiny scratch
before even touching the wheels even I didn't see because they could tell by the way the car was taken care of and looked that I
was a discerning customer. These guys won't scrape into my wheels guaranteed. Find those kind of guys near you.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
soundman98 (04-11-2020), why? (05-05-2020)
Old 04-12-2020, 04:56 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I remove the weights with non-marring plastic tools. Then, I use a non marring plastic scraper to get the adhesive off.
I hear heat gun also helps with the adhesive. WD40 was somewhat effective, but I've scraped it just dry as well.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
why? (05-05-2020)
Old 04-12-2020, 11:08 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Heat gun and patience with plastic tools. I wish I had more to offer, but I'm the kind of person to take a knife to it, sand down the scratches and re-paint it. Nobody will ever be able to tell and it's faster. I'm a cheap ass though...
Old 04-12-2020, 12:12 PM   #6
Muskoka800
Thanks all for your input.
I will seek out a plastic scrapper. I likely have one somewhere from my Reno business days. Also have Goo-Gone for the adhesive and a heat gun if need be.
No rush. Lots of time to kill while in lock-down.
Old 04-23-2020, 11:21 AM   #7
Muskoka800
Well, my plastic scrapper couldn’t get under the weights so I used a flat mini screwdriver to pry each weight up just enough to break the foam and them pulled them off by hand. Then I soaked the foam/adhesive with Goo-Gone and left it overnight. The next day a plastic scrapper took the adhesive right off easily.
Thanks All for your input.
Old 05-05-2020, 03:17 AM   #8
Tgp4eva
Drives: 2019 Toyota 86
3m general purpose adhesive cleaner
Tgp4eva is offline   Reply With Quote
Wheel Weights?? Jaredtri589 Scion FR-S / Toyota 86 GT86 General Forum 21 09-18-2019 01:51 AM
Oil weights for summer Whats that smell? Arizona 24 05-06-2016 02:14 PM
Wheel Weights FUN BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-24-2014 11:10 AM
What do you put in the trunk for Weights? cocoy_labuyo CANADA 33 11-16-2013 10:23 AM
Wheel weights BAE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-09-2012 10:16 AM
