Drives: 2016 Scion FR-S
Block Plate replacement worth it?
I’m just sort of thinking out loud here. For everyone with a manual, have you replaced/re-sealed the block plate? I think mine is allowing a very small amount of oil to leak out. It doesn’t seem to be a big issue, but does it only get worse over time? Was this a bigger issue on the earlier FR-S? Mine is a 2016
I’ve watched the FT-86 Speed Factory replacement video, and it doesn’t seem too difficult, with a lift. I would be worried about missing some of the old sealant that could get in the oil, or new sealant getting in the oil. ![]() ![]() Sent from my iPhone using Tapatalk |
#2 |
JDM Vaping Stance Nation
Drives: 2013 White
Issue among the earlier models. Some people replaced it with aftermarket but still leaked. Mainly due to the sealant being applied incorrectly I believe.
Clueless
#3 |
Rust bucket enthusiast
Once the sealant hardens, there should be no way for the sealant to mix with the oil after hardening.
I'd say if it's leaking, it's worth doing- if it starts dripping on the exhaust, you're risking a fire. Even if it is a low chance, it's worth getting it taken care of. |
#4 | |
Site Moderator
Drives: Stuff
Sealant shouldn't be an issue, even if you apply a lot. This isn't like the valve spring recall where it's super easy to "misplace" the coolant. There might be some used ones for sale on here, if not there will be one soon Or just take yours off an reseal it to try to fix it that way first.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#5 | |
Yeah it sounds like the replacement plate wasn’t installed correctly then. ![]() Sent from my iPhone using Tapatalk |
#6 | |
Ok now I’m moving this up on my car To Do list ![]() Sent from my iPhone using Tapatalk |
#7 | |
So just be careful getting the old sealant removed, and apply enough for a good seal with the new plate? Is there a specific tool that is best to scrape the old stuff off? I have some putty knives that might work. ![]() And if you put yours up for sale let me know. ![]() Sent from my iPhone using Tapatalk |
#8 | |
Low-Buck Ramp Truck
Drives: 2016 Scion FR-S Release 2.0 #502
I'm using the Verus plate which uses an o-ring to seal. It's a little more critical that you remove all sealant in the groove since that's where the o-ring sits. You probably wouldn't need to be so thorough if you're going back with stock plate and sealant.. |
#9 | |
Site Moderator
Drives: Stuff
-Dave
#10 | |
Ok gotcha, those are helpful tips! Sent from my iPhone using Tapatalk |
#11 |
#12 |
And you guys haven’t had any oil leaking with the Verus plate?
#13 | |
Site Moderator
Drives: Stuff
I suggested trying to reseal it cause it should, in theory, work. IMO the aftermarket plates are more for show. :shrug: But then I've never had an issue with an OEM one leaking when sealed correctly.
-Dave
#14 |
Low-Buck Ramp Truck
No issues so far, but my car is not a daily driver. Probably around 200 miles with no issues. Plate was installed 3-4 months ago..
| Glittery engine oil after short block replacement | msaikhan | Issues | Warranty | Recalls / TSB | 17 | 08-24-2019 02:17 PM |
| Block replacement under warranty - what all needs to be replaced? | chipmunk | Engine, Exhaust, Transmission | 8 | 02-16-2019 09:29 PM |
| If my car had an engine replacement: short block, am I still able to get a super char | VeganGirl | Forced Induction | 2 | 07-20-2016 08:35 AM |
| Full long block replacement, who has done it themselves? | post_break | Engine, Exhaust, Transmission | 14 | 06-20-2014 05:56 PM |
| Reverse light block off or replacement? | STS-V | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 04-10-2014 07:06 PM |
