Old 06-17-2019, 04:48 PM   #1
MilkyWitness
Drives: fdsgh
Clatter noise when giving throttle between 2-3k RPM in any gear.
asdf
MilkyWitness is offline   Reply With Quote
Old 06-17-2019, 04:54 PM   #2
StraightOuttaCanadaEh
Wes
Yeah it’s normal, you learn to live with it. Sounds a bit alarming but that’s just the sound of the engine/drivetrain
Instagram: @gt86ws
Old 06-17-2019, 04:55 PM   #3
MilkyWitness
Drives: fdsgh
Thanks for the reply, definitely is alarming! I know these engines make a ton of random noises, but this one scared me a bit as I don't know if its damaging at all.
Old 06-18-2019, 03:18 PM   #4
jflogerzi
jflogerzi's Avatar
Confirm all your Header bolts are tight. I had a weird rattle on first twin way back when I had my Borla UEL header as 1-2 bolts are a PITA to get tight. When i took it off I found 1 bolt really loose and another semi loose...
2013 Series 10 FRS #553
Old 06-18-2019, 04:22 PM   #5
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
I'm pretty sure I read on here people saying that the reverse lockout on the shifter can rattle a bit when applying throttle. Certain that isn't the noise? Mine does that sometimes depending on how fast I'm going, road quality, etc.
qcbaker is offline   Reply With Quote
Old 06-18-2019, 06:12 PM   #6
gravitylover
It could also be a heat shield. Every Subaru I've ever had including this one have a rattly heat shield at some point. This one rattles badly right at 4k RPM but not above or below. I stopped being concerned with it a long time ago. Hopefully they'll find that rattle when they have the motor out next month for the recall work to be done.
Old 06-18-2019, 11:09 PM   #7
Another alarming rattle is one that comes from the spring inside the clutch master cylinder. I get it very infrequently when it's particularly hot under the hood, always resonates at around 4K. Disappears as soon as I lightly tap the pedal.
Old 06-19-2019, 12:18 AM   #8
MilkyWitness
Drives: fdsgh
asdf
Old 06-19-2019, 05:34 PM   #9
radroach
Drives: car
@MilkyWitness
Make sure you haven't toasted your throw out bearing. Mine was rattling when hot, drove me nuts because I was afraid the fuel pump might have been going bad, or maybe timing chain, or other thing.
Sound clip. It would rattle worse when in gear.
https://streamable.com/0ka17
I know your car is new though but it might be worth checking (each TOB I had before lasted ~50k miles before needing replacement.)
Just had my throw out bearing replaced (along with other recall work). Got it back yesterday, seems to have fixed the issue.
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
Noise on Throttle Tip-In orangeblue Issues | Warranty | Recalls / TSB 8 02-12-2015 11:11 PM
Abnormal throttle noise RunHachi Issues | Warranty | Recalls / TSB 3 01-02-2015 09:35 PM
Clunking noise when on and off throttle and bumps DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-24-2014 12:18 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
