Old 11-06-2018, 09:28 PM   #1
stlgrym3
Does a cold air intake going to improve on my current setup?
I currently have ACE 350 header with Delicious flex fuel kit and custom tuned by Delicious. Would adding a cold air intake add any power to this setup? If so what brand do you recommend? Do I need a tune revision if an intake is added?
stlgrym3 is offline   Reply With Quote
Old 11-06-2018, 09:40 PM   #2
sid94
Drives: 2013 frs
The stock one with a drop in filter and a silicone hose is more then enough with the stock air box
sid94 is offline   Reply With Quote
Old 11-06-2018, 09:58 PM   #3
steve99
Drives: FT86
the stock intake is pretty good for NA.
Very little to be gained if you put a drop in filter and intake tube on stock intake and maybe cut of snorkel. even this is only worth may 3 hp or so.
If you do get a complete intake you will need a tune revision as most will alter the MAF (mass air flow) sensor calibration.
If you have a 2017 or later car the intake requires nothing as its already got better filter and intake tube than the earlier models
Header tune and E85 is best you do NA
Old 11-06-2018, 11:59 PM   #4
justinco
justinco's Avatar
Drives: 2022 GR86
I'd stick with OEM if you are staying NA. I've never seen any real gains from a few different intakes on my cars.
justinco is offline   Reply With Quote
Old 11-07-2018, 12:19 AM   #5
PulsarBeeerz
Drives: JRSC BRZ SOLD
Unless you are willing to fork out $2k for the Revolution Garage intake, the answer is no.
PulsarBeeerz is offline   Reply With Quote
Old 11-07-2018, 01:16 PM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
With the amount of money you would have to drop for a new intake and a tune revision for maybe a couple whp gain you're better off putting it towards a boosted setup.
tyler_win_photo is offline   Reply With Quote
Old 11-07-2018, 01:20 PM   #7
re-animator
Grimmspeed one has shown some gains, especially with an aftermarket tune to take advantage of the additional air.
You can "max out" the stock intake design by swapping the piping with a smoother metal or silicon pipe and either modify the snorkel or replace with an HKS or Greddy snorkel (will require you to remove the bumper). Add a cloth or foam drop in filter as well.
On a stockish tune either approach is worth about +5-7whp
re-animator is offline   Reply With Quote
Old 11-07-2018, 01:31 PM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Save your money on tires.
Current DD: M235i
8RZ is offline   Reply With Quote
Custom Jackson Racing Supercharger Cold Air Intake Setup CAI C38 C30 HKS Ram JRSC hirollaz Engine, Exhaust, Bolt-Ons 0 08-20-2018 07:34 PM
Need advice to improve stock setup maregt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 02-12-2018 06:11 AM
Perrin Cold Air intake CAI (black) and AVO silicone intake tube (blue) Joesurf79 Engine, Exhaust, Bolt-Ons 13 07-29-2016 02:38 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
