Old 06-20-2018, 06:08 PM   #1
Klassickk1
Drives: Toyota
Help!! shuts off once warm.
Hi
Car starts up with no problem (Cold start) runs.
But once warmed, idles dips even lower and eventually stalls out by it self. start up after warm is harder.
Things to point out when it runs there is CEL P0011 & P0021
What I have done is, New oil 0w 20 & filter, switch OCV around, swap out for new ones, open front case, checked timing (on its mark) lastly I change the both AVCS. and problem still the same. have another ECU re-flash & reset result the same. Even with those those codes, not sure if they are enough to stall out the engine. or something else is also in fault?
Thank ahead!
Klassickk1 is offline   Reply With Quote
Old 06-20-2018, 06:14 PM   #2
Originally Posted by Klassickk1 View Post
Hi
Thank ahead!
Engine mods?
Old 06-20-2018, 06:24 PM   #3
Klassickk1
Drives: Toyota
Stock!
The Following User Says Thank You to Klassickk1 For This Useful Post:
Tcoat (06-21-2018)
Old 06-20-2018, 07:06 PM   #4
steve99
Drives: FT86
Looks like you got the dreaded cam issues see the TSB section on this forum
Unfortunatly can be difficult to doagnose exact cause ,ecu,cam sensors oil contol valves or cam hydraloc actuators. Unfortunatly can ve quite expensive to fix out of warantee
Old 06-21-2018, 02:03 PM   #5
Klassickk1
Drives: Toyota
Thanks for replying, I believe I tried everything that was on there.
Do you happens to know what else I could do?
Old 06-21-2018, 06:10 PM   #6
steve99
Drives: FT86
You have done all stuff in these tsb ?
http://www.ft86club.com/forums/attac...1&d=1375302652
http://www.ft86club.com/forums/attac...0&d=1352490977
And you ecu has been updared to a ZA1JB01C or D if auto rom if its 2013 or earlier car
Also can you ise techstream to cheack the cam position initial learning values as per below
http://www.ft86club.com/forums/showp...&postcount=336
Or my values
http://www.ft86club.com/forums/showp...&postcount=337
If they are like the stigs then you dtill got problems with cams mine and ultrmaroons are normal values
Klassickk1 (06-21-2018)
Old 06-21-2018, 09:12 PM   #7
Klassickk1
Drives: Toyota
Or my values
Haven't had the car plug up to Teachstream yet. maybe I'll need to do that 1st.... Thanks!
Old 06-21-2018, 09:21 PM   #8
steve99
Drives: FT86
also might be worth logging when the stall condition occurs.
see what happens at idle when it stalls
normal warm idle ignition advance is around +13 degrees
AFR should be close to 14.7
long term fuel trim should be less than 10%
cams should be close to zero at idle as avcs not active
2015/6 auto had a tsb to update the auto trans computer firmware to avoid rough idle and stall as well if auto
Old 06-22-2018, 12:36 PM   #9
Klassickk1
Drives: Toyota
Its a Manual!! Thanks for those input!!
Help please. maybe battery bad but shuts off while driving Nefarious Issues | Warranty | Recalls / TSB 13 03-20-2017 11:14 PM
NAV unit shuts off when doing tight turns ReaperX43 Electronics | Audio | NAV | Infotainment 2 09-24-2014 10:32 PM
car beeping after engine shuts off mystic Southern California 10 04-14-2014 06:47 PM
EasyGo system. Car remote starts then shuts off Unsustainable Electronics | Audio | NAV | Infotainment 3 06-27-2013 09:42 PM
Nürburgring shuts down.. Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 12 04-10-2013 03:17 PM
