Old 06-07-2018, 09:12 PM   #1
StlBrz
Drives: 2014 Brz limited
Oft help??
Remove if not allowed or change to right section please.
Flashed to uel stage 2+v4. Threw the regular code for the uel headers but had another code come up but accidentally cleared it. And the abs light came on and didn’t go off until I restarted the car. Now when I turn my day time running light on and the indicator would not show up on the dash... any ideas what’s wrong?
StlBrz is offline   Reply With Quote
Old 06-08-2018, 04:01 AM   #2
steve99
Drives: FT86
Sounds strange oft like other flash tools only flashes engine ecu. Turn signals runnong lights and abs are controled by different computer in car.
Try removing a battery terminal for couple of minutes to reset all modules in car
Old 06-08-2018, 07:39 PM   #3
StlBrz
So I tried that and it worked it came back on but unfortunately it went right back to not working.... or not showing up..
Old 06-08-2018, 09:29 PM   #4
steve99
Drives: FT86
sorry dont rearly understand what your saying
what doesnt work and what doesnt show up. ?
Try flashing back stock tune and see what happens
are you using V4.03 version tunes, their was some bugs in 4.01
is your car auto what calid
Old 06-08-2018, 10:34 PM   #5
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
check battery connections and make sure it has a good charge before flashing
SuperTom is offline   Reply With Quote
Old 06-20-2018, 10:19 PM   #6
StlBrz
So I unhooked the battery terminals. After I put them back on everything worked fine. Then when I shut off my car, it went back to doing he weird thing. When I try and turn on my dtr lights they don’t come on unless it’s at night or I put it to where all my lights are on(ex headlight and everything else). Also I’m a manual brz with regular calid also on 4.03 tune. Turns out when I have my oft hooked in and I try to disconnect it sometimes, it’ll make traction control come on and a couple other lights. And then throw the code P0462. But it goes away after I restart my car.
Old 06-20-2018, 11:03 PM   #7
steve99
Drives: FT86
Don't plug in or unplug things into obd port of car with ignition on including oft. It can interrupt can buss comms of the cars various comuters and cause random cel codes and other issues
Tcoat (06-21-2018)
