Old 10-21-2012, 06:15 PM   #1
SpeedR
First86 / boat thief
Drives: MKIV Supra
CEL P219A?
And
P000a
P219a pd
Anyone have a good way to look this up?
Thanks
SpeedR is offline   Reply With Quote
Old 10-21-2012, 10:45 PM   #2
fistpoint
Drives: Supercharged Golf Cart
Goto any auto parts store, they'll do it for free and it only takes a minute or two.
fistpoint is offline   Reply With Quote
Old 10-22-2012, 03:53 AM   #3
Le86
Drives: Asphalt FR-S
Google.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-22-2012, 06:49 PM   #4
SpeedR
Drives: MKIV Supra
Originally Posted by Le86 View Post
Google.
Ya really did you find something useful, I didn’t but I was on my phone so not the EZ way to surf.
Old 10-22-2012, 07:23 PM   #5
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
P0219 Engine Overspeed Condition
Spartan65 is offline   Reply With Quote
The Following User Says Thank You to Spartan65 For This Useful Post:
SpeedR (10-22-2012)
Old 10-22-2012, 09:48 PM   #6
JohnnyP
Drives: 2013 Whiteout Scion Fr-S
P219A: Bank 1 Air-Fuel Ratio Imbalance
P000A: Camshaft Position "A"- Timing Slow Response Bank 1
As per Fr-S repair manual. So what exactly did you do to get these codes?
JohnnyP is offline   Reply With Quote
Old 10-22-2012, 10:07 PM   #7
Synack
Boosted
Synack's Avatar
Drives: Sideways
Autozone does it for free. Google for free. AND we have an Issues Section
http://www.ft86club.com/forums/forumdisplay.php?f=72
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 10-23-2012, 01:04 AM   #8
SpeedR
Drives: MKIV Supra
Drive fast and turn.
Old 10-23-2012, 02:26 AM   #9
JohnnyP
Maybe you need to get some Whiteline parts then 'cause I go fast and turn all the time and have yet to get a MIL (except for maybe a flashing trac light if it's still on).
Old 02-04-2013, 08:44 PM   #10
fenton
i got this code too.
Not to much useful information online.
I also have P119F.
Running @Visconti stage 1
fenton is offline   Reply With Quote
Old 03-07-2015, 10:15 AM   #11
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
I got the same could
Now supposedly it's something to do with the fuel air ratio mix but alot of other crap also. But what I did was check my air filter come to find out it was dirty replaced it and the rough idling went away also. Now on the people with the traction control light on it might be something wrong with your ecm what I would do is this check all the fuses for the ecm use the owners Manuel I belive there Is 4 in the engine bay and two in the inside take them all out and then unplug your battery after that wait a while like 10 min and check your filter while you do that then put all fuses back in hook your battery up now if the lights pop up as soon as you start your car something is more possibly wrong with your ecm then anything else becuase the air flow sensor won't turn the traction control light on that's something with the ecu. I did this and it got rid of the engine light. I didn't have the traction light until I took off one of the ecu fuses out which mad it run loud like over timed and the traction light was on. But when I took all the ecu fuses off discounted the battery and changed out the air filter made sure there wasnt a squirt or something inside haha all went away good luck hope this helps
Albaro08 is offline   Reply With Quote
Old 03-07-2015, 02:23 PM   #12
tyrantcf
Drives: '16 WRX, CBR1000RR
wat.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 03-07-2015, 06:19 PM   #13
Albaro08
Albaro08's Avatar
That's what i did but light still came back on took longer this time tho
Old 01-05-2016, 03:54 PM   #14
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
I have this light too. Fearing it won't be covered under warranty because of my tune. Is there any more information on this?
RavioliG is offline   Reply With Quote
