| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 Subaru BRZ with Invidia N1
So im kind of new the world of wheels.. anyway im just going to jump right into it. i just got a set of my dads old saab wheels for xmas... the only thing is that they have 5x110 bot pattern. the dimensions are 17x8 et 35. I already know that im going to have to use 5x100 to 5x110 adapters, butttt the real question is about off set and fitment. Im looking at adapters that have a 25, 20 or 15 mm thickness so the offset might change from 35 to either 10, 15, 20. if anybody can help me with what the best adapter size is, that would be great.
#2 |
Country Boy 4 Life
I would suggest that you get different wheels. But, since you asked....
The thinnest adaptor is going to be the easiest to make the wheel "fit". You will need camber bolts, two sets, to adjust camber. This is just for the front. For the rear you will need LCA to adjust camber. This is a 16x8 +25 with one set of camber bolts maxed out and lowered 1" on 225/50 tires. Your wheels, with a 225 tire and the thinnest adaptor will stick out an additional 5mm. via Imgflip Meme Generator
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | TheWhiteWizard13 (12-27-2017) |
#3 |
this makes me sad, but i do appreciate the insight. what do camber bolts do exactly? im still such a noob it makes my head hurt lol
#4 | |
Country Boy 4 Life
They add camber. ![]() GOOD LUCK!
I LIKE TIRES! |
#5 |
LMGTFY
Drives: 13 FRS, 91 Miata
You have two options.
1. 15mm adapters and but loads of camber. 2. Get different wheels. I'd go with the second option personally. That or see of you can get them re-drilled to 5x100. |
#6 |
Drives: Legacy GT
Sell them to a guy with a saab and get some wheels that fit.
| The Following 2 Users Say Thank You to jamal For This Useful Post: | TheWhiteWizard13 (12-27-2017), wparsons (12-28-2017) |
#7 | |
This has one of he most helpful answers, thank you for your feedback, even if I drill them the bore isn’t the same sadly 😓 Sent from my iPhone using Tapatalk Pro |
#8 |
#9 |
The title to this thread should read “Finding the right wheels for my 5x100 hubs”
This is such a SAAB story! |
| The Following User Says Thank You to Grady For This Useful Post: | wparsons (12-28-2017) |
| Wheel Adapters... Will I die? | Haroush | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 01-17-2019 11:11 PM |
| FS: isc wheel adapters 15mm, and eBay 25mm wheel adapters | jay92 | Brakes, Suspension, Chassis | 4 | 08-19-2016 07:17 AM |
| I need help finding the right wheel for DD in the dirt. | Hot Wheels | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-15-2016 12:41 AM |
| FS: Sparco steering wheel setup/ b2autodesigns wheel adapters | sebastiansim | NY / NJ / CT / PA | 1 | 11-12-2015 08:57 AM |
| Has anyone ran wheel adapters? | DarkCard | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 01-24-2013 10:07 PM |
