Drives: 2013 FRS
Current thinking on oil baffles/pickups?
I'll be installing a new oil pan in a couple weeks, and would like to get any other recommended supporting mods out of the way while I have the oil pan off. I am finding conflicting information as to whether an oil baffle is recommended. Post #19 in this thread suggests it isn't needed, while comments here and post #5 here say it is.
Furthermore, I learned about the Killer B oil pickup but there is even less information on this. Can anyone weigh in on whether this provides any real benefit? I'm trying to keep this simple so I'm not looking at Accusump/dry sump. Thanks in advance. |
#2 |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#3 |
Remember there are at least two main reasons for oil starvation at the bearing level. The most obvious is lack of oil at the pickup, not very comin with these engines. The next is a restriction in the oil delivery system, a galley to small to get the oil to the bearing. A less common one is using the wrong weight oil for the system as operated. Too thin and will escape and not hold pressure, too thick and will not make it to the bearings in sufficient quantity.
How worried are you? Have you seen a drop in pressure? The fixes you mentioned will take care of that. Have you rebuilt the engine to some different tolerances? Finally what kind of driving are you using the car for? |
#4 |
Purist
Ive read all your quoted posts. The biggest word that sticks out to me is RACECAR.
If your car only does daily duty I would recommend the Killer Bee Oil Pickup. You have the pan off, its a good simple upgrade. It comes with a new Gasket. If you are going to be hard on it or track/autox it frequently an Oil Baffle sounds like a good Idea. Blue Moon and Moroso look like fine candidates. Depending on how deep your pocket is you can also look into a Reimax Oil Pump. That is if you track the car. Hope that helps. This is all opinion, but Ive been doing a lot of the reading you have on Oil Issues. Mine has 50,000+ miles and Ill be going down the same route.
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) Last edited by Westen86; 06-15-2019 at 01:41 PM. |
#5 | ||
Drives: 2013 FRS
No, I haven't seen anything that worries me, I just want to do as much as reasonably necessary while I have the oil pan off for convenience and peace of mind. No, engine is completely stock at the moment. Eventually will upgrade the rods and whatever else is recommended for more power if I decide to go that route. Quote:
#6 |
BAE
Drives: Asphalt FRS
I run the Bluemoon Baffle since i track it occasionally. Better safe than sorry
#7 | |
Purist
| Current well known car brands that you would never buy | Th3rdSun | Other Vehicles & General Automotive Discussions | 153 | 10-12-2019 05:58 PM |
| Part Out *Local Pickups Preferred* (Outside Philadelphia, PA) | Doneil3757 | Wheels and Tires | 5 | 03-29-2018 10:37 PM |
| How Much slower is current F1 | Joakim3 | Other Vehicles & General Automotive Discussions | 21 | 12-03-2015 02:07 PM |
| Current brz Prices | Pkush | BRZ First-Gen (2012+) — General Topics | 36 | 10-15-2014 05:02 PM |
| CURRENT car name? | Obja | Scion FR-S / Toyota 86 GT86 General Forum | 81 | 10-20-2012 02:51 PM |
