Old 04-06-2017, 07:02 PM   #1
GNious
Drives: 2017 BRZ (CWP)
Looking to upgrade to a different catback (quad tip)
First off, quad tip is merely because I want it to be different. I've been looking into the Blitz nur, but have read that it can be pretty restricting due to the piping size. This would be a no-no since I plan on upgrading the rest of the exhaust system soon as well. EDIT: Boosting is likely to happen in a year or so also.
I also don't want it to sound stock, because that's lame. Any info from those that have gone the same route?
GNious is offline   Reply With Quote
Old 04-06-2017, 07:39 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Restricting how so?
If you don't plan on doing turbo or supercharge, any normal 60mm piping catback system will work perfectly fine for your needs.
Old 04-06-2017, 07:42 PM   #3
GNious
Oops my bad, forgot the mention that I do plan on boosting eventually as well. Won't be for a year or so though. Think it should be fine still?
Old 04-06-2017, 09:12 PM   #4
mav1178
mav1178's Avatar
Honestly, unless you have an upgraded turbo that is much larger than the normal bolt-on kit, or you are running complete 3" piping, having 60mm piping on an exhaust for your average run-of-the-mill turbocharged car is not a restriction that you can feel.
As for the sound, the exhaust is one part of it. If you want a louder exhaust from whatever quad tip exhaust you have, get a front pipe without a cat or resonator.
Old 04-06-2017, 11:34 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If you're afraid of the Blitz being restricting, maybe you should consider a shop fabricating you one. If you plan on supercharging, diameter doesn't really matter in terms of power. If you turbo, 3" would be the route you want to go for max gains.
tyler_win_photo is offline   Reply With Quote
Old 04-07-2017, 12:20 AM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
The only quad tip exhausts I can think of (HKS, TRD, Blitz, and MXP) probably won't fit your standards. MXP is probably closest. Otherwise, I'd say buy whatever exhaust you deem less restrictive and then get a shop to weld on some quad tips.
MS, CSCS, TSAC-F, CPT
Old 04-07-2017, 10:32 AM   #7
StRacngtC06
StRacngtC06's Avatar
Drives: 2013 Whiteout FR-S
Im looking at this as well... would that be the best option as getting a shop to just weld on quads to whatever sytem you choose? I bought the new trd '17 rear lower for quad tips
Sent from my SM-N920P using Tapatalk
StRacngtC06 is offline   Reply With Quote
Old 04-07-2017, 03:43 PM   #8
mav1178
mav1178's Avatar
Ultimately the answer will depend on what you actually want out of your car.
Do you want to turbocharge and make 250-275RWHP? If so, a 60mm exhaust is by no means a restriction.
Do you want to maximize your power gains from your kit? Then consider a custom exhaust w/ quad tips.
Old 04-10-2017, 01:27 PM   #9
sirsol66
Drives: 2013 FRS- Hot Lava
MRT in Michigan is going to be making a quad exhaust (fits TRD rear add on diffusers, 1.0 rear lip, and TRD Japan rear) in the next month or so; they're using my cars to prototype them.
This is their current setup:
http://www.shopmrt.com/2013-2016-Sci...t-p/91z151.htm
They sell a full exhaust as well; header back.
sirsol66 is offline   Reply With Quote
Old 04-10-2017, 02:27 PM   #10
mav1178
mav1178's Avatar
I hope they realize US and JDM TRD rear bumper are completely different and won't fit.
I already went down this road many months ago by test fitting a TRD-spec quad exhaust to a RS 1.0, the exhaust tip basically sits on the bumper.
-alex
StRacngtC06 (04-11-2017)
Old 04-11-2017, 02:01 PM   #11
sirsol66
-alex
I own 5 twins so we're trialing it between a bunch of the cars:
Series 10 with the Japan TRD garnishes
2.0 with the TRD Japan full rear lip
1.0 with the OE rear lip
2017 860 with the kouki TRD rear lip
I'll post up what we find but I suspected what you mentioned.
Old 04-11-2017, 02:12 PM   #12
StRacngtC06
With regards to the new TRD Kouki rear kit, what size and type exhaust tips would you suggest? I just ordered mine from japan and I am in search of exhaust? I am looking at getting an ARK Performance Grip with custom tips, but unsure of tip fitment.
Old 04-12-2017, 01:31 PM   #13
sirsol66
No idea as I dont have the car nor the lip yet. My 860 landed at the port today, so I'm assuming I wont see it until May mid~end.
All I can tell from talking to TRD Japan is that the muffler does have a different PN. However, that could be a function of the flange as I know that's different from the 12-16MY cars. I'll post up what I can find.
We're building the quad exhaust on my series 10 first, and then I'm going to move onto the 2.0 (full TRD rear lip) and then the 860.
The Following User Says Thank You to sirsol66 For This Useful Post:
StRacngtC06 (04-12-2017)
Old 04-13-2017, 07:23 AM   #14
StRacngtC06
My TRD Kouki rear lip just showed up from Japan last night. I will take measurements and post possible fitments. Local Toyota was excited to see it.
J2 Quad Catback Exhaust SOLD djrbash Engine, Exhaust, Bolt-Ons 11 10-12-2016 08:06 AM
Help! TRD Quad tip VS TRD Dual (D) tip catback 86King Engine, Exhaust, Transmission 3 07-23-2016 03:11 PM
WTB J2 Quad TIP Catback. Worstenemy453 Want-To-Buy Requests 1 01-10-2016 01:23 AM
J2 Quad catback exhaust? bcmakesiteasy Engine, Exhaust, Transmission 22 06-01-2015 04:43 AM
FS: J2 Quad Tip Catback Exhaust (Cheap) CNYBRZ Engine, Exhaust, Bolt-Ons 18 07-02-2013 01:02 PM
