Old Fart
High Output Alternator
Does anyone know a good high output alternator for the FRS? I need to change out my alternator because I need more draw.
#2 |
Time Traveller
Damn!
The stock alternator is rated to output 130 Amps. I've electronically supercharged my car for the past 2 years on that without issue. What do you plan running? A server farm? Seriously though, check this thread for some potential leads. http://www.ft86club.com/forums/showthread.php?t=29850 |
| The Following User Says Thank You to DAEMANO For This Useful Post: | bear89103 (04-19-2016) |
#3 | |
Old Fart
So putting a second battery should isolate those away from the engine. I just need to upgrade the alternator to make sure it's outputting high enough to run both. |
#4 | |
Time Traveller
Haha ok, well just so you know. The OEM alternator is currently recharging these 3 batteries in my car on a pretty much constant basis without a problem. 2x Big Crank ETX16 & 1x Odyssey PC680. Give it a shot, it might just work for you too depending on whatever your setup is. |
| The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | bear89103 (04-19-2016), FRSBRZGT86FAN (04-20-2016) |
#5 | |
Old Fart
#6 |
I bet it's your compressor motor.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jawn (04-19-2016) |
#7 |
Old Fart
Could be. Right now I've been driving two days with just the compressor and main attached to the battery and it seems to be ok. AFR and fuel trim a little higher than with just the main. But it's at least stable and not jumping up and down. |
#8 |
Is that with it running? DC motors throw a LOT of electrical noise.
#9 | |
Old Fart
Yes. That's with it running. |
#10 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | bear89103 (04-20-2016) |
#11 |
Old Fart
LOL no worries. And I will take any of the help possible. Even if it's to chase down things I've already done. That helps me to think through all the possible issues. Thank you!
| The Following User Says Thank You to bear89103 For This Useful Post: | 86kahl (04-20-2016) |
#12 |
Drives: 06 Ford Mustang
hey bumping this - did anyone ever find a solution?
#13 |
If you have a bad or insufficient ground connection that would reduce draw.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| power output oft tunes | denso | Software Tuning | 3 | 09-15-2015 07:53 AM |
| Any output on M7 T-Titan or MXP Catback | Simon99 | Engine, Exhaust, Transmission | 10 | 09-13-2015 04:22 PM |
| Subwoofer output for Bespoke Premium | bebopblues | Electronics | Audio | NAV | Infotainment | 5 | 11-29-2014 04:27 AM |
| pt546-00140 Sub Output | dgerny | Electronics | Audio | NAV | Infotainment | 1 | 01-09-2014 02:56 AM |
| Interesting Findings about BRZ Audio Output | Chad_W | Electronics | Audio | NAV | Infotainment | 14 | 05-03-2013 09:28 PM |
