Old 12-14-2016, 04:44 PM   #1
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Wheel Studs
Looking for a place in Mesa that can replace all 20 of my wheel studs with the new ARP ones I have.....
IceFyre13th is offline   Reply With Quote
Old 12-19-2016, 02:53 PM   #2
IceFyre13th
Drives: Mazdarati
104 views and not one suggestion, Brakes Plus wants $500.....that is way too much for this........I could do it myself but do not have a press.
Old 12-19-2016, 02:59 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
My suggestion would be to go buy a harbor freight press and do it yourself.
Replacing each stud for a shop is going to take a decent amount of tinkering and work, so it's best relegated for a speed shop that's setup for this sort of thing.
A HF press can go pretty cheap if you get a coupon, I think I got my 20 ton for $80 on a 4th of July sale.
Use it once and you'll realize how nice it is being able to do jobs like this on your own!
Edit: I am not local, as you can see, but I do a lot of mechanical work on my own cars. This job isn't bad if you follow the DIY, and are comfortable doing a brake job.
JazzleSAURUS is offline   Reply With Quote
Old 03-07-2017, 02:56 PM   #4
IceFyre13th
Drives: Mazdarati
With only the one answer that was to by a press (would of still cost more, even with the 20% coupon).
I just had to replace my tires, Discount Tire recommended Network Alignment in Gilbert as another factory stud broke during the tire replacement.
ALL 20 studs replaced by them for $148 .00 and under 45 minutes.
Hopefully the ARP replacements will last longer than the crap the factory used.
Old 03-07-2017, 09:17 PM   #5
renfield90
The Stig's German cousin
Sorry I missed this thread first time around.
Network Alignment in Gilbert is good people.
I used SRD in Tempe, they took a little longer (and were a little more expensive), but they're also good people and I enjoy giving them my business. I don't remember how much, it was about 4 years ago.
Studs are doing great, and have MANY wheel changes to their credit - I put race tires on before each autocross and remove them afterwards. You will be very happy with your purchase.
My studs are probably due for a new set though. If you change wheels as often as I do, you should consider studs and lug nuts to be wear items. And just like brakes, you don't want to discover what happens when they wear too far.
Old 03-07-2017, 09:43 PM   #6
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
As I am fairly new to this car and this forum, I get the feeling that the studs are crap. Does this mean, that if I go out and buy new tires from someone other than my Toyota dealership, every time they rotate the tires (free rotation is usually included with tire purchase), I should be concerned that they may break one or more of the studs? Does buying the new tires from my Toyota dealership guarantee that they will cover a problem with the studs? I'm not trying to be a dink, here, I'm just finding out how often these studs fail. Thanks so much in advance!
winstonscifi is offline   Reply With Quote
Old 03-08-2017, 07:09 PM   #7
IceFyre13th
Drives: Mazdarati
Every time the dealer broke one they fixed it free, but discount tire or other places may / will not. At a "normal cost" of $50 per replacement it adds up fast, yes the factory studs are crap..........
ARP makes replacement studs for our car in standard and extended lengths, and a great investment in the long run. Super strong and long lasting.
My total out of pocket was less than $250 and I ordered the Studs from Summit Racing.
https://www.summitracing.com/search/...pe/wheel-studs
The Following User Says Thank You to IceFyre13th For This Useful Post:
winstonscifi (03-08-2017)
Old 03-08-2017, 07:35 PM   #8
renfield90
I cross threaded one stud on my own (8 years doing tire changes on my last car, NEVER an issue). Discount tire cross threaded a second one before I upgraded to ARP. I know some people who haven't upgraded literally keep spare OEM studs on hand because they know it's going to happen.
If you're not changing wheels once per month or more, upgraded studs will last the life of the car. ARP also has a bit of dead space at the tip of the stud with no thread - makes it almost impossible to cross thread (it will be very obvious when you do, it's a great feature).
The Following User Says Thank You to renfield90 For This Useful Post:
Old 03-11-2017, 09:05 PM   #9
.Kyle
Drives: it's grey
Bring the parts to cave creek. I can do them in short order.
.Kyle is offline   Reply With Quote
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 11:50 AM
In Need of Wheel Studs Hurby Southern California 1 10-03-2016 02:25 AM
WTB WHEEL STUDS TomShugoy Want-To-Buy Requests 0 02-08-2016 07:44 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
WTB OEM Wheel Studs Anthony Want-To-Buy Requests 8 08-27-2014 04:22 PM
