Old 01-25-2017, 01:14 AM   #1
dallenj
Drives: Grey FR-S
Is my engine blown?
Everyone in my local group seems to think it's an exhaust leak coming from my header. It sound worst to me what do you think. Let me know.
dallenj is offline   Reply With Quote
Old 01-25-2017, 01:48 AM   #2
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
hard to tell.
get someone to block the tail pipes while idling and listen at the front for whether the sound changes
Die$eL is offline   Reply With Quote
Old 01-25-2017, 02:04 AM   #3
dallenj
Drives: Grey FR-S
Originally Posted by Die$eL View Post
hard to tell.
ill try it
Old 01-25-2017, 03:38 AM   #4
swarb
You should list your mods and if any were recent. And also mention how you drove the last few minutes or hours in the car before you noticed the problem.
Edit. Op has nitrous...
Old 01-25-2017, 03:46 AM   #5
dallenj
Drives: Grey FR-S
I recently got Dyno tuned for my nitrous. After that everything was fine drove it for a few days with no issue. All of a sudden I start hearing a lot of noise coming from the passenger side of my car. I have ran open headers before on this car and it sounds very similar but it is making a more metallic noise which concerns me.
Old 01-25-2017, 03:48 AM   #6
dallenj
Drives: Grey FR-S
Mods include full exhaust. 1320 header and over pipe j2 front pipe and a greddy cat back. An nx plate kit running a 75 shot from 4500 to 7000 rpm
Old 01-25-2017, 05:08 AM   #7
Die$eL
Die$eL's Avatar
hmm, burnt valves perhaps...
Old 01-25-2017, 10:01 AM   #8
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
In my opinion, that's definitely an exhaust leak. Coming from just dealing with a major internal engine failure that isn't what mine sounded like. Actually given your mod list, it's hard to say. Either way, from the video I'm hearing an exhaust leak.
demasrv is offline   Reply With Quote
Old 01-25-2017, 10:42 AM   #9
FRS Justin
Drives: 2013 Asphalt FRS
That sounds like you have a cracked header or a blown exhaust gasket. possibly your header is loose, tighten bolts and check for cracks by jacking up vehicle start it and feel for warm air or do it the easy way and start vehicle and squirt it down with soapy water.... good luck
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 01-25-2017, 10:45 AM   #10
jasonojordan
Drives: 2013 satin white brz limited
jasonojordan is offline   Reply With Quote
Old 01-25-2017, 02:00 PM   #11
swarb
Pull the bottom cover and re-torque the exhaust parts. My guess is an exhaust leak from j2 front pipe or j2 gaskets.
Old 01-25-2017, 04:05 PM   #12
dallenj
Drives: Grey FR-S
the bracket on the j2 that bolts to the trans has broken off so that might have put some extra stress on the header.
Old 01-25-2017, 05:15 PM   #13
swarb
did you use the j2 gaskets? The company itself is a low priced company and they would skimp out on gaskets. My guess is you blew a gasket.
Old 01-25-2017, 06:46 PM   #14
DJCarbine
Thupercharged
DJCarbine's Avatar
Sounds like exhaust leak, especially the burble after the throttle blip.
Most surefire way to know?
Jack 'er up and make sure its stable. Let the car idle, and get underneath after you take off the underpanel. Look/feel for leaks near header/overpipe/midpipe joints. Also check any welds where pipes merge in the header.
If that is indeed a leak, its so bad I imagine Hellen Keller could find it
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
no sale, rekt
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 09:32 PM
Supercharger and blown engine Triumphrider Forced Induction 81 10-21-2014 03:49 PM
Blown Engine kombatlion Forced Induction 27 06-18-2014 06:21 PM
BRZ Blown engine question Mujen84 Forced Induction 118 04-02-2014 05:04 AM
