Drives: Asphalt 2013 FR-S
Light steering wheel feel after coilovers? - yes it's aligned
Anyone experience a lighter steering wheel feel after installing coilovers?
Tein flex z - lowered about 1.8" - 4 clicks back from full stiff, and fairly close to stock alignment specs, nothing fancy. The steering wheel feels really light and floaty though. My buddy just installed the same coils in his car and he has noticed the same thing. What gives?! |
| The Following User Says Thank You to BDotG For This Useful Post: | ajcarson11 (01-19-2016) |
#2 |
Drives: Whiteout FRS
Interesting I did not experience this. Hopefully someone can chime in real soon
#3 |
Drives: FRS
is your car lowered evenly from front to rear? are you still at 0deg front camber? the rears will naturally camber in around -2.5ish with that amount of drop, but the front needs to have negative camber dialed in manually by the tophats on your teins.
#4 |
Drives: 2005 Toyota Camry
what is "close to stock alignment specs'?
#5 |
I think it is pretty much as close to factory specs in the front and back for alignment, think if I dial the front camber in a bit negative it will take care of this?
#6 |
#7 | ||
Drives: FRS
im just wondering if it might be a setup of 0 camber up front, and -2.x camber in the rear. and maybe thats why the steering feels all light? i dunno though, just a guess. im no suspension expert :o
#8 | |
Drives: 2015 BRZ
I'd get it checked out by a real race shop that will do a good alignment. 99% of drivers don't really care if the alignment isn't perfect, so most NTB-style alignment shops don't have techs that do tight alignment specs. Usually. |
| The Following 4 Users Say Thank You to GSpeed For This Useful Post: |
#9 | |
#11 |
Drives: 2013 Subaru BRZ Limited (Black)
Same 'light steering' feeling. Running -2.6 camber in front and -2.5 camber in rear with Flex Z.
Sorry to revive old thread... but the Flex Z is relatively new, so still relevant! |
#12 |
Drives: '13 FRS - STX
What are the caster numbers?
#13 |
Drives: frs
I had that problem after lowering and adding 17x9 +35 wheels. Fixed it with the Whiteline anti-dive/caster correction kit #kca 434. Worked great returning positive steering feel and quicker and better return to center after a turn.
#14 |
Drives: Whiteout Scion FR-S
Did you check the tire pressure? Did you use a digital tire gauge? I just couldn't resist a digital tire gauge joke.
![]() Tires do make a difference to the steering feel on this car for me: BF Goodrich Rival 225/45R17 - weighty feel; Yokohama Advan V105 225/45R17 - good, mostly neutral; Bridgestone Blizzak WS80 205/55R16 - light and too quick, doesn't easily track straight. It seems that many things will affect the steering feel for this car. Subscribed, as I am interested in the same suspension options as listed hear and would like to see some good recommendations that have actually been tried and work.
My cars always dress formally. They all wear black tires.
| Tags |
| coilovers, light, steering |
| ABS and Slip Light on after steering wheel re-install | Yamajee | Issues | Warranty | Recalls / TSB | 11 | 03-29-2017 01:56 PM |
| Best Steering Wheel Column for Feel - Rake and Reach | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-21-2015 10:24 PM |
| OEM Steering Wheel Reinstall...Light Still On? | dizzario | Electronics | Audio | NAV | Infotainment | 13 | 06-22-2014 10:23 PM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 05:52 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) — General Topics | 8 | 12-08-2011 12:16 PM |
