| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2014 Scion FRS
Easy Axle Replacement
The easiest way you can replace an axle on these cars.
| The Following 4 Users Say Thank You to thekevinvo For This Useful Post: |
#2 |
Drives: Crapcan
Should replace the nut. I find they don't hold well after being removed. I have a couple spares I keep in my stuff.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#4 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
Tips
This process in this video worked worked for me. First side ~90min, second side ~40 min.
here is the process checklist I used: BRZ AXLE REPLACEMENT Tools: - pry bar or fork - torque wrench - 32mm socket (axle nut) - 17mm socket and crescent wrench - 19mm socket and crescent wrench – for - High temp grease STEPS: - Lift car, remove wheel. - straighten (round out) the punched/bent part of the axle nut so it will spin freely - Remove the big axle nut (32MM) with breaker bar. - remove 19mm outer bolt on lower control arm - MARK the bolt/nut position first!! ----- oem bolts may be 17mm? Can’t remember. - remove 17mm on lower trailing arm - CAREFULLY hammer axle inwards to free it from the spindle – don’t hit the wheel studs or the axle splines! - use a screw driver / tool to push the axle through the spindle - pivot the spindle left/ front of car and tap it through until it comes loose. - With a wide pry-bar or fork, lever the inner spline connector from the rear diff - Remove old axle from the diff and from the hub - INSTALL NEW AXLE - start at inside, hand place it, line up the splines - Replace old axle nut half-way on to absorb hammer bows. Use a few blows at the hub end of the axle with a 4lb hammer to get the whole axle it to seat past the interior circlamp. - Pivot the spindle left (forward) as much as possible, then angle the outer part of the axle and fish the end of axle into the spindle Wiggle and jiggle to seat the outer splines fully into the hub. Thread on the Axle nut finger-tight Reinstall the bolts for the lower control arm and lower trailing arm. May need a jack to position the LCA. Once suspension bolts are done, Torque down the Axle bolt to 160 foot-pounds With a nail set, punch the axel bolt sleeve to stop loosening. DONE ! BOLT TORQUES:å Axle nut 160 foot-lbs Lower control arm (SPL) bolt - 59 lb-ft Lower trailing arm bolt - 81 lb-ft |
| The Following 2 Users Say Thank You to canyons For This Useful Post: | gnarjunkie (10-06-2023), RedReplicant (09-07-2023) |
#5 |
Tip: support the axle.
For aligning the replacement axle:
swivel the spindle+hub to the font as much as possible. Stick a piece of wood between the spindle and the coil-over to keep it out of your way. I extra jack stands so I used those to support the new axle in a straight line while tapping it into the diff and then wresting the outer edge into the Hub. Much easier when your're not holding the axle up at the same time! . . |
| The Following 2 Users Say Thank You to canyons For This Useful Post: | RedReplicant (09-07-2023), Wally86 (09-05-2023) |
#6 |
Drives: 2013 frs base
I just did axles on an 05 Forester. Same axle configuration as the Twins. This time I put a little oil on the diff end of the axle over the lock ring. Push the axle in until it contacts the lock ring then take up the "slack" in the CV. An quick impulse push sends it home. No BFH needed.
| The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (09-06-2023) |
#7 | |
Drives: '23 GR86, '17 BRZ
I didn't have an appropriate piece of wood, but I wedged a rubber wheel chock between the LCA and the knuckle and used a jackstand to hold the axle at the right angle. Then it was just a couple taps and it was in. I liked the thought of using the old axle nut to give a good surface to tap on as well. |
| Easy REAR Wheel Stud replacement - Shade Tree Mechanic Style | Dake | DIY (Do-It-Yourself) Guides | 24 | 10-07-2020 12:56 PM |
| DIY Request: Axle Removal/Replacement | xjohnx | DIY (Do-It-Yourself) Guides | 10 | 09-22-2016 07:30 PM |
| Axle replacement | xjohnx | Engine, Exhaust, Transmission | 55 | 08-22-2016 04:50 PM |
| How-To axle replacement, ish... | Josh Ehlert | DIY (Do-It-Yourself) Guides | 2 | 07-19-2016 03:01 PM |
| Any easy fix for chronic wheel hop / axle tramp? | ft_sjo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-14-2013 09:08 AM |
