Old 08-16-2016, 02:12 PM   #1
bshep
Drives: 2013 scion frs hot LAVA
Horrible sound while decreasing speed in gear (no clutch)
My husband and I just bought a 2013 frs 2 weeks ago from a car lot. It drove like a gem when we first got it all the way up until 2 days ago when this horrible noise started. The noise is coming from somewhere under the car (can't really distinguish if it's from the dif or the trans). While driving above 20mph and letting off the accelerator the noise starts. Ithe sounds like something is loose, shaking, and grinding. If I push the clutch in or take it out of gear the noise starts. When it first started 2 days ago it wasn't very loud now it is horrifically loud and driving my husband crazy! I have gone through a bunch of the forums whIle waiting for permission to post on here and I've seen a few threads but no real answers. Anyone ever experienced this or have any ideas to point me in the right direction. Oh the car has 30000 miles mostly stock besides exhaust, coil overs, light weight pulleys, and a cold air intake. To my knowledge thats everything. Help please!
bshep is offline   Reply With Quote
Old 08-16-2016, 02:15 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Post a video
guybo is offline   Reply With Quote
Old 08-16-2016, 02:18 PM   #3
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
go to the dealership-should still be under warranty?
asdf is offline   Reply With Quote
Old 08-16-2016, 02:22 PM   #4
bshep
They called me and said they could look at it today, but would have to go from there. I'll try to take a video on the way!
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 08-16-2016, 02:24 PM   #5
asdf
asdf's Avatar
Drives: #0517
best of luck to you! curious to see what they say
Old 08-16-2016, 02:25 PM   #6
bshep
Thanks me too. Hoping for a loose bolt that I couldn't see!!! A girl can wish.
Old 08-16-2016, 02:32 PM   #7
Throw out bearing.
Drakiv (08-19-2016), JazzleSAURUS (08-16-2016)
Old 08-16-2016, 02:33 PM   #8
bshep
But it doesn't make any noise at all when the clutch is engaged. The way I understood a bad throw out bearing it would make the noise when the clutch was engaged not disengaged.
The Following User Says Thank You to bshep For This Useful Post:
Tcoat (08-16-2016)
Old 08-16-2016, 02:54 PM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Opposite.
I agree that I think it's a throw out bearing.
If the dealership will do it, I vote have them replace the whole clutch kit, including flywheel while they are in there. If you're taking it apart you may as well depending on condition. If they'll comp a part of an Exedy stage 1 kit, it's a nice unit and makes the pedal firmer.
JazzleSAURUS is offline   Reply With Quote
Old 08-16-2016, 03:24 PM   #10
bshep
Thanks waiting now for them to take it back to check!
Old 08-16-2016, 03:35 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
If it is the TOB or some other part of the clutch, it makes me wonder what other mods were done to the car before it was traded in?
Did you see the carfax and maintenance records?
Old 08-16-2016, 03:36 PM   #12
bshep
Yea it had nothing on the carfax. Now records that I Remember seeing.
Old 08-16-2016, 04:12 PM   #13
number_Un0
Drives: 2013 FRS 10 series #0001
my car is making the same noise, it started happening after my transmission was replaced under warranty for the 5th gear grind, I've been driving it like this for 8k miles now. (im at 32k). I've just been to lazy and didnt feel like putting my stock exhaust back on and take it to the dealer.
number_Un0 is offline   Reply With Quote
Old 08-16-2016, 05:00 PM   #14
bshep
They said the entire rear end is gone, but they are going to fix it and cover everything besides a rental.
Drakiv (08-19-2016)
differential, loose bolt, transmission
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 09:10 PM
Runduce 6-Speed Transmission Gear - 500hp botbs Engine, Exhaust, Transmission 10 11-22-2015 03:59 PM
is it ok to slip my clutch often in 2nd gear when my rpm is below 2k? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 88 06-17-2015 07:12 PM
What's this clunk sound coming from 2nd gear after letting go of the clutch ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 17 04-30-2015 03:14 AM
Cold morning and horrible grinding/screeching sound Books Issues | Warranty | Recalls / TSB 1 11-14-2012 03:18 PM
