Old 02-03-2014, 08:04 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
GTX2863R vs GTX2867R vs GTX3071R
Heres how I chose my compressor.
I don't agree with the majority about choosing a turbo that is at its maximum to acheive the power you want. Sure you end up with more "area" on a dyno plot, but running a turbo well out of its efficiency creates heat. Heat is bad mmmkay.
I made this mistake on my ae86, running a tomei m8270 (which is comparable to a gt2876r, sort of) and sure it makes 430hp on pump and looks awesome ( and will peel 4th gear as the turbo spools on the street ) but the IAT's and the car in general runs way too hot. On the street its fine. On the track it only takes a lap for it to get too hot. I'm looking at upgrading to a gt30 frame turbo.
Don't select a turbo from someone elses dyno!!
This point gets lost on forums. Also, don't just read a review that says "OMG I have this turbo and its da bomb!" Have they tried another turbo either side? Probably not. They're probably just amazed at how much better it is than their previous turbo, and ignore the fact (and will probably get annoyed when you ask) if they considered a different turbo either side. You can't trust or read into someones review that has not reviewed/experienced anything comparable. /end rant.
AE86 dyno for reference. Great for street. Great for forum steez. Not efficient. Not good for track. Two lines are 0.9 bar, 1.1 bar.
Anyway, heres the 3 compressors I shortlisted.
If you think my boost levels are too high, remember this is at the turbo, not the motor. I have assumed a system with 2psi pressure loss.
The gtx2863r I think it well suited to either a stock fuel system (260whp ish) or a 300whp car that is a street car, with light track work.
THe gtx2867r I think is well suited to this power level and boost. You can see how it passes through the islands where they are at their widest.
The gtx3071r I feel is oversized for 300whp on anywhere but track only. I would use this for track only even those the compressor efficiency is marginally lower because the gt30 turbine is much more efficient in this same range over the gt28. But i want my car (even though its a track car) to be decent in slower targa type racing as well. I also think to really see the gains of this turbo, you need to be aiming for more power, for me, that means built motor, box yada yada. I know some are getting 400hp - over9000 hp on the stock motor / box. But they're not tracking them. (Well I don't believe they are.) And if they are, thats great news for me, it means my selection has a good amount of redundancy.
I realise all turbos will do well more power, you can see this on the comp maps, but the efficicency falls away, and I'm not going there. The gtx2867r has its peak efficency basically right were I want it, basically smack bang in the middle of the revs I use at the track (5500 - 7500) If anything its marginally to low, and I'd prefer it a little higher, but theres so much variations/assumptions/estimations in this, that it would be wrong to look at it in that much depth.
Anyway, thats how I made my decision.
diss7 is offline   Reply With Quote
The Following 5 Users Say Thank You to diss7 For This Useful Post:
Boris_Petrov (03-07-2019), DriftEightSix (02-03-2014), jamesm (02-03-2014), Ravenna (01-02-2017), Sportsguy83 (02-04-2014)
Old 02-03-2014, 08:05 PM   #2
diss7
So after I checked with a buddy of mine that works for Garrett NZ about my initial estimations, he agreed that they seemed overly harsh, with respect to airflow requirements.
With a couple of his suggestions, I have gone back to trying to make the 63r work.
Basically picked two targets, 320whp on pump, 400whp on E85. Do I see myself using E85, maybe. But, as has been pointed out to me, good future proofing. If I could confidently say NO to the E85 option, it would be best to get a gt2860rs over the gtx2863r. It is basically the same compressor map at moderate boost levels, but much cheaper. But the gtx2863r has much more ability in the higher boost range. Plus its billet wheel should help spool slightly.
Some points:
I chose to make target hp at 7000rpm as this seems to be where most fa20's are making it, give or take. Certainly not at redline. Most likely to do with stock head/cams, amd/or losing VE past 7000rpm.
I pumped up VE from BA's suggest of 0.90 to 0.95. Reasoning being that the motor is high compression, direct injection. Yada yada.
I have plotted down to 3000rpm. Now this DOESNT mean that the turbo will spool and make full boost at 3000rpm. I don't think it will. But, it shows that if the motor is able to get the turbo to spool this early, the compressor can support it.
Anyway, this is what I ended up with.
Looking at the results and I'm liking what I'm seeing.
The pump line is showing good efficency. Dropping the boost would result in the same or less efficiency as the islands narrow. The lines past the optimium island are also at about 45 degrees at this point, so less boost, less airflow, but you'll probably be in the same islands.
You could maybe go a little higher on the pump line, to 14 or 15psi. The islands get slightly wider and the past-optimium lines start to steepen. 17-18psi seems like it would place the line where the islands are at their widest, so I would estimate thats where the best efficiency would be found. However, I haven't plotted that, as I think the pump line as is, is pretty much where the knock threshold is (thereabouts) due to the high static compression.
The E85 line is there as sort of the limit as to how far I would push it. Looking at the map, the past optimium lines are near vertical, so reducing hp target, would lower the boost and airflow req'd and lower this line. It would bring the plots into better past-optimium zones, as again, they're near vertical at this point.
So after seeing these results, and getting reassurance that while these are still only estimates, they are most likely more accurate than my own initial estimations, I'm sticking with the gtx2863r.
Just quickly about the turbine housing, I'd already decided to go 0.86 instead of 0.64, purely based on the overwhelming preference of tuners already on this platform that 0.86 performs better. But my buddy pointed out that again this turbo is very similar to the gt2860rs (disco), and the same arguement over 0.86 and 0.64 has been debated to death when talking about the disco. He pointed out that comparing the two spooling on an sr20det, the 0.64 spooled sooner but slower, the 0.86 spooled later and faster. They both reach maximum boost at basically the same point. 0.86 will also cope with the higher rev range much better, and certainly with the e85 line.
Asurendra (02-03-2014), Calum (02-03-2014), jamesm (02-03-2014), OjiGeorge (02-04-2014), trigger happy (02-06-2017)
Old 02-03-2014, 08:42 PM   #3
jamesm
i went with the gtx2867r... kinda wishing i would've went with the 3076r after riding in @Sportsguy83's car. actually not kinda, definitely .
The Following 5 Users Say Thank You to jamesm For This Useful Post:
diss7 (02-04-2014), hmong337 (02-05-2014), OjiGeorge (02-04-2014), pmccut (02-04-2014), Sportsguy83 (02-03-2014)
Old 02-03-2014, 09:32 PM   #4
diss7
Problem with the 3076r is its a big turbo, made for big power on a 2L.
2863r can get to 400whp on e85 as above, so hard to jump up to a 3076r unless you're talking much higher than that.
No doubt it feels fast though. When it eventually ramps up it'll be like a rocket coming on boost. But at the sacrafice of so much mid range.
I'm sure if it was plotted, you'd see how under utilised the 3076r is. You can see it on the gtx3071 graph above.
This graph gives a good visual to what I'm talking about. You can also see why another guy I know is really wanting to try an efr6758
I don't know the specifics of this graph. But the way each turbo comes on says a lot about how they'll be like as a daily.
Old 02-03-2014, 09:45 PM   #5
xwd
I'd love to see some real-world boost plots from people. PTuning as I'm sure you are aware is getting good results out of the GT3076R but I don't know how good the on/off throttle response would be with that turbo even in their layout, I can't imagine it's great when not at high RPM. For me it would be a tossup between the GTX3071R and GTX2876R but not sure what size housing I would use. Fuel makes a big difference as well, if I go FI on a stock motor the car will likely only ever see E85 which helps as well with spool and response when tuned correctly.
The Following User Says Thank You to xwd For This Useful Post:
diss7 (02-03-2014)
Old 02-03-2014, 09:48 PM   #6
jamesm
you'd think it'd spool slow... but it really doesn't at all. it's hardly noticeable compared to my 2867r, and the advantage in overhead is just immense.
i'll be swapping soon.
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-03-2014, 09:49 PM   #7
OrbitalEllipses
Drives: Attitude
Got a ride in prototype form and it's surprisingly not laggy at all. Not at 3K rpm in any gear; remember we're talking 12.5:1 compression here.
Old 02-03-2014, 09:54 PM   #8
diss7
Agree the overhead is definitely an advantage. For me, I just looked at 400whp on e85, saw the 2863r can do it efficiently, and knew I would never be looking for more than that.
That's awesome. Not only for him, but its all realitive. If a 3076r is spooling that early, then the 2863r will be redonkulous
The Following User Says Thank You to diss7 For This Useful Post:
jamesm (02-03-2014)
Old 02-03-2014, 10:01 PM   #9
xwd
I had a built 2.5L WRX with a 9:1 CR motor and a fairly small turbo for autocross that was like an on/off switch. It made 17-18PSI almost instantly when tuned on race gas. I'm not sure I'd want that in a RWD 86, I'd want a little more linear boost build up since you can't just mash the gas like AWD... PTuning was supposed to be tuning/dyno'ing a car with the 3071R, I'd be really interested in seeing that especially with a .63A/R housing.
Old 02-03-2014, 10:12 PM   #10
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
On a vw 2L (10.5:1 DI)I went from a T25 2871r to a vband 3071r w/ a billet wheel and Tial housing. Additional lag was very minimal. The 2871r was great at around 325whp on pump. But the 3071 made over 400whp at the same ~20psi with a bit more timing and 460whp @ 27psi and w/m. Both were driveable, it was just the supporting mods and lack of traction that made all the horsepower not that much fun. But you never realize that till your there.
cruizin01 is offline   Reply With Quote
The Following User Says Thank You to cruizin01 For This Useful Post:
charged86 (12-29-2014)
Old 02-03-2014, 10:16 PM   #11
diss7
315whp and sudden boost sounds like heaven.
I wont have to run 55psi in my rear tyres anymore.
I've had a few silvias with similar power. 300whp, no lag, and light rwd car, running 215's. Tha best.
Old 02-03-2014, 10:20 PM   #12
diss7
I wanted to see this too, and really rated this kit. But I just don't buy into all that piping not affecting response.
I know when I had my sti, and I went from top to front mount IC, the extra IC piping gave a noticeable decrease in transient response. I didn't like it.
Old 02-03-2014, 10:39 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I would love to see this too since im set on the PTuning kit. curious tho, you mention if you ever go FI on a stock motor it would be strictly E85, isnt that incredibly damaging to the fuel and cylinder heads?
Old 02-03-2014, 10:51 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I still would love to see someone make a low turbo mounted kit with a TMIC. Sure some hood modification is required but...that response tho...
Which turbine size for gtx3071r? diss7 Forced Induction 67 02-02-2014 09:19 PM
EFR6258 vs GTx2863R diss7 Forced Induction 25 12-01-2013 11:15 PM
Garrett GTX2863R turbo, TiAL v-band wastegate Turbowned Engine, Exhaust, Bolt-Ons 10 11-27-2013 03:07 PM
