Drives: '15 Scion Frs Steel
Doors are all kinds of messed up
So one early sunday morning me and my girl both open our doors at the same time and the strongest wind i have ever felt came and ripped the doors out of our hands. Now I have two kinks on both side and they dont close properly. See pics and youll see what im talking about. Any advice? Body shop is charging me 1500 for both doors together. I dont know if its the hinges, the latches or the aligment of the doors that is messes up. Help please. My doors dont close, took it for a car wash ans got water all inside my car and they open 90 degrees.
Sent from my SGH-T999N using Tapatalk |
#2 |
Ouch! You could adjust the hinges where they bolt to the body just so the door latches but if where the hinge is attached is bent or kinked thats not good but fixable. Just a lot of labor time. Get more estimates if you can get it to a shop.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#3 | |
#4 |
Loosen the bolts on the body side hinges and move the door rearward. You should have some help since the door is heavy and awkward to move by yourself.
#5 |
Panda Trueno
Drives: No twin now.
Sounds about right. That is a lot of labor, and obviously there are gaps. It is probably a combination of bent hinge and door metal.
To fix it looks like they will have to do metal work, paint work, and replace parts. |
#6 |
Drives: Ultramarine toyobaru
In picture 4, is the door rippled all along the side or is it a weird reflection?
#7 |
Those are not going to adjust out no matter how hard you try. Body work is required.
#8 |
Drives: 2013 satin white brz limited
Deff looks rippled to me.
#9 |
Double post.
#10 |
Drives: 2013 Raven FR-S
would insurance cover anything like this? technically mother nature played a part in this. hopefully your deductibles are low for comp.
#11 |
Drives: 2JZ FRS
The door frame is probably buckled. More than likely two door shells, all hinges, door stay assemblies. If you get lucky, just hinges and door stays, but I doubt it.
#12 |
I was thinking of going to the insurance i just dont want my rates to go up. Im also young and dont know the most about how insurance works
#13 |
#14 |
Drives: '13 BRZ
You and your girlfriend both opened your doors at the exact same moment, and the wind was so strong that it ripped the doors out of both of your hands? Are you sure the car didn't roll out of a garage with the doors open?
| All kinds of boost! Innovate, HKS, AVO, Greddy, Full Blown + supporting mods! | No Limit Motorsport | Forced Induction | 214 | 05-23-2017 03:45 PM |
| What kinds of gains do you expect with E / I and tune? | Partial Stall | Engine, Exhaust, Transmission | 66 | 05-10-2012 11:56 AM |
