Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
02-03-2013, 05:43 PM | #1 |
Drives: RAVEN
Deos this car not warn you when you are low on washer fluid?
I know that I am anti-electronic nannies, but on the way back from the ski slope, I ran out of washer fluid with no chance for a fill for many miles.
I guess I got used to my other cars having an idiot light to warn me before I ran out. Am I missing something? |
The Following User Says Thank You to NOHOME For This Useful Post: | cgrey (02-04-2013) |
02-03-2013, 05:44 PM | #2 |
Seņor Member
Drives: 2013 SSM DZE BRZ
No.
02-03-2013, 05:45 PM | #3 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
No warning light. Does come with a dipstick in the washer fluid tank though.
02-03-2013, 06:01 PM | #4 |
Drives: Asphalt FRS
Sure it does! When you pull the lever and you notice the stream does not travel up as far as it did the first time you ever used it, that's your "low fluid" warning. Attention to detail, there soldier!
The Following 2 Users Say Thank You to Wolfking For This Useful Post: | mangostick (02-03-2013), OnkelC (02-04-2013) |
02-03-2013, 06:41 PM | #5 |
PDI "Not"
I just checked mine and discovered that the reservoir was basically empty. Car is brand new and I've only used the spray 1or 2 times.
I filled it up and it took almost 1/2 of a Gal. Kind of weird.. I'm going to keep an eye on this... maybe there's a slow leak.
2013 Asphalt / MT
Olympia, Washington |
02-03-2013, 06:50 PM | #6 |
Red is Fastest
Mine held almost a gallon but not empty.
02-03-2013, 06:51 PM | #7 |
Drives: 2017 Subaru BRZ PP
That's good. My current car has a light that turns on and off even with a decent amount left and its so annoying.
Toyota + Subaru =
02-03-2013, 06:59 PM | #8 |
Sarcastic SOB
Based on the other electronics in the Subie I wouldn't be surprised if they had the warning sensor, although likely not.
Based on this car being a Scion and having some good standard performance gear, it's expected for stuff like this to be absent. I have lived with and without this feature, no biggie. NOHOME I'm still waiting for a you to add a positive or enthusiastic post to this forum. Maybe in the summer!
02-03-2013, 07:00 PM | #9 |
Drives: FR-S MT
There is a warning system. Shortly before it runs out, the stream gets weak.
02-03-2013, 07:18 PM | #10 |
Drives: Ultramarine FR-S 6MT
Mine was pretty much totally empty. Took the whole gallon with room to spare.
Stupid road salt has me using it constantly. As for warning, the cleaning performance on the passenger side will fall off first. Of it isn't cleaning as well overe there, look to refill! That's what I observed anyway. |
The Following User Says Thank You to Ingen For This Useful Post: | raptor87 (02-03-2013) |
02-03-2013, 07:20 PM | #11 |
3.141592654
Drives: 2013 Galaxy Blue BRZ
1st world problems...
The Following User Says Thank You to Boost_Junkie For This Useful Post: | CaptainSlow (02-03-2013) |
02-03-2013, 08:21 PM | #12 |
No shit. When you pull the lever and nothing comes out, it's empty. Not that difficult.
Ultramarine 2013 Scion FR-S 6MT
The Following User Says Thank You to CaptainSlow For This Useful Post: | immortal_suby (02-04-2013) |
02-03-2013, 08:36 PM | #13 |
Drives: WRB BRZ
this car also doesnt warn you when you're about to over cook your rice. this is outrageous!
Similar Threads | ||||
Crush Washer Sizes | Eric1855 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 55 | 08-30-2021 02:21 AM |
Washer Mod? | 636 | Engine, Exhaust, Transmission | 64 | 02-20-2018 04:08 PM |
FYI - Washer Fluid light | Ben_G | BRZ First-Gen (2012+) -- General Topics | 48 | 01-03-2013 04:18 PM |
Engine oil drain plug washer | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-28-2012 11:28 AM |
front washer? | Filipino Royale | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2012 02:06 PM |
