Old 01-17-2019, 10:29 PM   #1
jaskarnx
Drives: 2014 Scion FRS
Rocket Bunny V1 Wheel Spec Questions
Hey everyone,
Im about to grab some Work Meister S1 wheels
5x114.3
Rears 18x12 -8
Fronts 18x9.5 +12
Rears tires 275/40/18 nitto nt555 g2s
Front tires 215/40/18 continental extreme contacts
Would these still fit, worried with the 18x12 -8 is that still possible?
Thanks
jaskarnx is offline   Reply With Quote
Old 01-18-2019, 08:40 AM   #2
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
Please don't stretch a 215 on a 9.5" rim that is a fail....that 275 will be stretched significantly on a 12" rim as well.
The sidewall profile is really tall on a 275/40 you should be on a 275/35 to stay closer to stock size diameter. Otherwise your rear tire will be almost 2" bigger around than the fronts.
Axis2011KR is offline   Reply With Quote
The Following User Says Thank You to Axis2011KR For This Useful Post:
Leonardo (01-18-2019)
Old 01-18-2019, 12:22 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
^ I agree. If you run a 275/35/18. Then a 235/40 is a good diameter for the front. Or maybe a 285/30. 245/35 stagger.
Usually, guys run close to zero offset ( if not a little in the negative) in the front for a 18x9.5 wheel on the V1. You'll probably want a +15 spacer (adaptor?) to make the front match your aggressive rear.
18X12 -8 is wider than most run. The offset looks like it will work with a bit of poke. I mean if the fender is +65 to +70, (depending on whose measuring I guess) Then your 18x12 -8 will stick out 73mm more than a flush wheel @ -3 camber on stock body.
Also, if you are getting 5x114.3, do you have 5x114.3 hubs, or are you planning on adaptors?
Theres plenty of room in the front for an adaptor... Not sure about the rear. It looks to be pretty maxed out by my calculations.
I dont have a widebody, but am pretty good with offset calc.
Can you test the rear on your car? Do you have the V1 kit installed?
Edit: Words.
I LIKE TIRES!
Rocket Bunny Wheel offsets kitabrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-16-2017 08:22 PM
Rocket Bunny Vs GT500? And other questions! xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 16 04-25-2014 12:22 PM
