Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-27-2022, 07:00 PM | #1 |
Drives: 2013 frs base
Best source for axle boots
The boots on 2013 FRS are starting ooze some grease. I bought a spare axle and I am going to "rebuild" all 3 using Redline grease and adding a vent tube. I'd like to buy just the boots and not a kit.
What's the best source for them thar boots? |
08-28-2022, 04:03 AM | #2 |
Wheels for Brains
Subaru or Toyota parts department
The Following 3 Users Say Thank You to EndlessAzure For This Useful Post: |
08-28-2022, 09:40 AM | #3 |
08-29-2022, 08:13 AM | #5 | |
Drives: '13 BRZ TLM Spec
Order Here If the grease in your old axles is just old and has liquified, just clean and repack them.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following 2 Users Say Thank You to Opie For This Useful Post: | blsfrs (08-29-2022), RedReplicant (09-18-2022) |
08-29-2022, 09:17 AM | #6 |
@Opie: Thanks for posting the video. It's been about 10 years since I took apart an axle so I need the refresher.. I ordered my boots from subarupartspro.com They were $17each + shipping. I found some random straps on ebay. I need to check to see if they are large enough.
08-29-2022, 03:51 PM | #7 |
Drives: '13 FRS - STX
Inspect the cups (for lack of a better term), I found mine deformed, axle failure was not imminent but certainly possible. Mine were only deformed in one direction, I heard an old trick was to flip them L/R if that was found, these will be my spares and they're marked as such.
The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
09-12-2022, 12:53 PM | #8 |
Repacked with grease and rebooted. I bought a used left axle and put it on the right. I put my right on my left and will keep my old left as a spare.
Cleaning and repacking the outer cv was the worst part. Everything else was easy peasy. |
The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
09-18-2022, 06:56 PM | #9 |
Finished up repacking my spare axle. This is my original left. 100k miles and 20ish track days.
There was some "heat" discoloration at the lip of the cv joints. I noticed it on my other axles as well. Is this from usage or the manufacturing process? |
09-18-2022, 08:46 PM | #10 |
Manufacturing, the boot would have melted if it got that hot on the car.
The Following User Says Thank You to strat61caster For This Useful Post: | blsfrs (09-18-2022) |
09-18-2022, 10:13 PM | #11 |
Drives: Crapcan
Probably case hardened the bearing surface.
09-26-2022, 09:43 AM | #12 |
Well, I suck at repacking CV joints. My left axle let go after 3 sessions. The next one (left again) let go after 2 sessions. The "cups" were hot to touch even after sitting for 1/2 hr. I eyeballed the amount of Redline grease that I put into the cup. It was 1/2 to 2/3's full. I packed grease around the bearings to hold them in place for installation. Was I supposed to pack the boot with grease too?
I'm biting the bullet and sourcing OEM axles today. |
09-27-2022, 11:09 AM | #13 |
Drives: 2014 GT86
Hmm .. are you boosted? Or do you run thick wheel spacers? Or maybe you have lowered car a lot? If later, i'd consider some diff riser kit to reduce back CV joint angle / reduce load & wear on it.
09-27-2022, 12:35 PM | #14 |
N/ A powered. 198 hp on last dyno pull. Lowered about 1" with Tein Flex A coilovers. I am running Federal 525 rs rr on 9x17 Apex Arc 8 wheels no spacers. Maybe I put the axle in backwards. (LOL)
Similar Threads | ||||
Dss axle boots riped | IsaiahW | Engine, Exhaust, Transmission | 0 | 07-09-2022 10:42 AM |
AutoStyled - Hand-Crafted Shift Knobs/Shift Boots/Brake Boots Are Now Here! | RallySport Direct | Interior Parts (Incl. Lighting) | 4 | 06-23-2017 01:37 PM |
