| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: SWP BRZ
Greddy Magnatic Oil Plug with OEM Washer
hello everyone. when i did my oil change, i changed my oem oil bolt to Greddy one and used washer that came with. i am going to do my next oil change soon and wondering using OEM washer is fine with Greddy bolt.
I am trying to avoid possible leak here. anyone with Greddy oil bolt, little help? |
#2 |
Drives: 2014 BRZ Limited SWP
Should have no issue
| The Following User Says Thank You to Kuri For This Useful Post: | zc06_kisstherain (08-03-2014) |
#3 |
Drives: JAWS
I use an OEM washer with the Greddy magnetic bolt. Holding fine so far
| The Following User Says Thank You to JB86'd For This Useful Post: | zc06_kisstherain (08-03-2014) |
#5 |
Drives: 2013 BRZ Premium Black
I use the OEM one as well. No issues to report
| The Following User Says Thank You to fantah For This Useful Post: | zc06_kisstherain (08-06-2014) |
#6 |
Drives: 2013 Scion FR-S 6M Argento
Mine leaked with the one the plug came with, its been fine with oem washers
| The Following 2 Users Say Thank You to Jrdad For This Useful Post: | brz408 (08-10-2014), zc06_kisstherain (08-06-2014) |
#7 |
Drives: SWP BRZ
#8 |
Drives: SWP BRZ
little late but i changed my oil last saturday
because of that magnetic bolt, when i unbolt, it stuck at pan!!! and oil splashed to group not to oil drain container! haha. anyway, there is no weak as metnioned after changing oil. |
| Beware || oil drain plug washer (when changing your oil) | mav1178 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 11-14-2021 07:07 PM |
| Greddy Oil Drain Plug - Leaking | Pokeguyjai | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 09-25-2016 05:16 PM |
| Washer for oil drain plug missing? Kind of urgent. | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 02-07-2014 02:43 PM |
| GReddy Magnetic Drain Plug BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 01-05-2013 11:19 PM |
| Engine oil drain plug washer | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-28-2012 12:28 PM |
