Old 07-03-2014, 12:15 AM   #1
jonbonazza
Syste!m too lean bank 1
So do I have a faulty o2 sensor, or is something else wrong?
Sent from my Nexus 7 using Tapatalk
jonbonazza is offline   Reply With Quote
Old 07-03-2014, 02:35 AM   #2
Fastbrew
Drives: 2014 Pearl White BRZ
Stock or modded?
Fastbrew is offline   Reply With Quote
Old 07-03-2014, 02:38 AM   #3
jonbonazza
Sorry probably should have mentioned. Here is the mod list that for the engine:
Invidia N1 cat back
Invidia catted FP
Motiv OP
FT86SF catted header
AEM intake
ECUTek tune
Nothing has changed in a month or so. Just came on on the drive home from work today.
Old 07-03-2014, 02:53 AM   #4
Fastbrew
Geez - hate to make guesses but it could be a ton of stuff. Maybe as simple as the sensor but possibly dirty or faulty injector(s). Maybe the tune needs a little tweak.
I'm going to step aside and let a pro give you better advice but I would start with the cheap stuff and move up the chain. Dealer might not be much help
Old 07-03-2014, 02:55 AM   #5
jonbonazza
Yea, i need to do another logging run anyway, so i figure ill monitor them at the same time. If the sensor was bad though, wouldnt the logs be skewed?
Old 07-04-2014, 12:52 AM   #6
jonbonazza
Okay so I did some logging this evening and the afrs regularly went into the 15s. Also, every time I shifted or let off the gas (but NOT stopped in neutral) my afrs were exactly 20. I think this is just how the reading is done. This was using the Torque app for Android.
What is considered "too lean" for this car?
Old 07-04-2014, 01:31 AM   #7
Fastbrew
I think this is too lean
http://www.ft86club.com/forums/showthread.php?t=56141
I only pointed that out to show how long it takes to actually do major damage.
What fuel do you usually run?
PS - that sounds very lean to me Again - someone may tell me I'm wrong but crikey....
Old 07-04-2014, 01:43 AM   #8
jonbonazza
91 is the best I can get (easily) in my area. I feel like it's too lean too, but it's weird that I have been on this tune for a couple thousand miles and this just happened out of nowhere. I was informed, however that if it was the o2 sensor, a second code would be thrown as well, and I am assuming the same for a fuel injector, so I guess I'll get some EcuTek logs and hit up my tuner.
Old 07-04-2014, 01:49 AM   #9
Fastbrew
Yes - and maybe get a read from something external to the vehicle on that AFR.
What has your MPG been like?
Old 07-04-2014, 01:52 AM   #10
jonbonazza
How do you read afrs external to the ecu?
Old 07-04-2014, 01:55 AM   #11
Fastbrew
Device in the exhaust reads and calculates. Same way they used to measure emissions at the DMV before plugging into the OBD port...
Old 07-04-2014, 01:59 AM   #12
jonbonazza
I see. Hmm okay. I'll need to locate one of these devices, I suppose.
Old 07-04-2014, 02:01 AM   #13
Fastbrew
Good luck and take it easy until you figure it out. Something is def not right.
Old 07-04-2014, 02:06 AM   #14
jonbonazza
Also, if it means anything, Torque reads this for the "rediness":
lean at idle only woode Forced Induction 5 05-03-2014 05:48 PM
PO171 SYSTEM TOO LEAN BANK 1 rmdrag0n Engine, Exhaust, Transmission 23 03-02-2014 01:50 AM
Recommendation for lightweight wheels without breaking the bank ayau Tracking / Autocross / HPDE / Drifting 6 11-08-2012 03:23 PM
Bank Robbers Throw Money In Police Chase travace Off-Topic Lounge [WARNING: NO POLITICS] 5 09-13-2012 02:00 PM
Scion FR-S FIRST DRIVE Tour in Baltimore at M & T Bank Stadium ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 3 04-29-2012 08:43 PM
