Old 12-02-2014, 05:53 PM   #1
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Spacers & Handling Performance
Hey All,
Question to everyone running wheel spacers. I'm looking at getting 20mm spacers for the front and 25mm spacers for the back wheels of my BRZ. Probably going with the H&R ones (or Perrin which are made by H&R)
I've read some people saying that the spacers make handling sluggish. Anyone can confirm this?
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 12-02-2014, 06:26 PM   #2
Koa
I don't track or autox my car, so take this with a grain of salt.. but installing those exact mm spacers gave a very minimal, if none, change in how I perceived handling characteristics of my 86.
What I can say, however, is that the spacers really tie the look together, along with lowering springs.
I'm lowered on sportlines, 20f/25r mm spacers, and SPC camber bolts up front.
Old 12-02-2014, 06:35 PM   #3
Pkush
I had the same question in mind...and I drive a Series.Blue too. I want to keep the wheels, but they're so not flush it hurts my eyes.
Pkush is offline   Reply With Quote
Old 12-02-2014, 06:57 PM   #4
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
I have the same exact spacers. H&R too. It feels a little different. My turns seem a little wider? Might be a placebo effect lol Im also lowered on some KWV3s.
scottxnizzle is offline   Reply With Quote
Old 12-02-2014, 07:19 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
I use 20/25 spacers on my stock wheels with winter tires on it because I get used to my 17x9+35 summer wheels.
I didn't notice a difference in handling on the stock setup. I wouldn't take it to the track or anything like that, but for driving around on the street, it's fine.
The Following User Says Thank You to Foobar For This Useful Post:
Koa (12-02-2014)
Old 12-02-2014, 07:38 PM   #6
kberkel
kberkel's Avatar
same.
Just got my winter tires swapped and the place wouldn't bolt the wheels onto spacers since they've stripped them in the past.
So I paid for all the work, then went home, took all the wheels back off, bolted on the spacers, then the wheels again
I'll never drive without them on stock wheels, it's that much better.
kberkel is offline   Reply With Quote
Old 12-03-2014, 10:55 AM   #7
iLaw
iLaw's Avatar
Thanks for the replies everyone. Sounds like it doesn't really change how the car handles much.
I'm looking at getting Pro-Kits to lower the car. Only one person mentioned camber bolts. Anyone else require camber adjustment parts once lowered?
iLaw
Old 12-03-2014, 11:36 AM   #8
Koa
What's a pro kit?
If you're lowering 1 inch or so (RCEs, Eibach pro) then camber bolts up front aren't necessary... but you will be running negative camber in both fronts and rear.
If you're going anything more than 1 inch, camber bolts up front are a must for a good alignment, and rear camber options are then highly suggested
Old 12-03-2014, 12:00 PM   #9
Gunman
Drives: 2019 Mazda Miata RF
Widening the track is generally good for handling, but with spacers you are changing the front scrub radius, which can change steering feel. You're also changing the loading on the wheel bearings.
The Following 2 Users Say Thank You to Gunman For This Useful Post:
8R6 (12-03-2014), SubiePig (12-03-2014)
Old 12-03-2014, 12:33 PM   #10
8R6
8R6's Avatar
Drives: FRS
on the street, you'll almost never experience a difference... but whether on the street or track, with big spacers like that, your wheel bearings will definitely hate you.
8R6 is offline   Reply With Quote
Old 12-03-2014, 12:41 PM   #11
RFB
RFB's Avatar
Drives: FRS
And - large spacers and the extra bolt metal can add a lot of unsprung weight !
CERBERUS
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Gunman (12-03-2014)
Old 12-03-2014, 02:11 PM   #12
iLaw
iLaw's Avatar
Originally Posted by Koa View Post
What's a pro kit?
http://www.ft86speedfactory.com/eiba...-s-brz-98.html
iLaw
Old 12-03-2014, 03:12 PM   #13
executivekoala
executivekoala's Avatar
Drives: fr-s
I run full set of spacers front and rear, on multiple cars. It will make the handing lazier if the are not hub and wheel centric. You wont notice in the rear but in the front you will, other than that I've not had issues just be careful not to over torque lugs and take the spacers off every few months and clean them and you are good.
executivekoala is offline   Reply With Quote
Old 12-03-2014, 03:45 PM   #14
Koa
by far, the best spacers out there. For value and quality. You cannot beat $100 for a set.
http://www.corner3garage.com/V3-Spac...WRX_p_482.html
what bushing should i get for better handling nearvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-15-2014 04:26 PM
Guys, would you say our FRS's handling is same or better than BMW's? 2082FRS FR-S / BRZ vs.... 125 06-05-2014 11:30 PM
Best handling car? gt8613 FR-S / BRZ vs.... 154 10-07-2013 09:57 PM
Best handling IS ever ! All real footages Whitigir Other Vehicles & General Automotive Discussions 0 06-17-2013 08:12 AM
A Testimony To The FR-S's Handling skoodge Scion FR-S / Toyota 86 GT86 General Forum 25 06-08-2012 06:36 AM
