| Software Tuning Discuss all software tuning topics. |
Drives: 2013 Scion FR-S 10 Series MT
Torque App & Open Flash Tablet
Hey guys, I had a quick question that I didn't find in any searches. I plan on getting an Open Flash Tablet sometime this winter, or even as early as next month.
I was also interested in checking out my oil temps and other stuff, and was considering purchasing a Bluetooth OBD Scanner + Torque Pro. My question is... does the OFT pretty much do everything that the Torque App can? If so, I'll just skip it. If not, can anyone list some of the stuff that the Torque App can do that the OFT cannot? Just trying to determine if I should get the Torque App now and the OFT later, or if I should just wait and get the OFT only. Any and all help is appreciated. |
#2 | |
Drives: BRZ Limited
| The Following User Says Thank You to fstlane For This Useful Post: | hmong337 (06-19-2015) |
#3 |
Drives: '13 DGM BRZ Limited
It's not something anyone can compare right now except maybe Shiv from Vishnu because no one has seen what the logging features will be like on the OFT yet. Since both pull their data from the OBDII port, they should be capable of getting the same information. It then comes down to which interface you like better.
#4 |
Drives: Subaru BRZ with Delicious Innovate
@fstlane has anyone figured out how to monitor 'knock correction CA" in the real time logging screen without switching to the knock add on? I haven't messed with configuring your own layout. Can you give me a little more info on how you did this?
I too like the Torque app. I have EcuTek but the interface that the Torque app gives you is fantastic. You don't the refresh rate that EcuTek will give you but it is also half the hassle. No cord, and you have real time data in an easy to read display. |
#5 | |
Drives: BRZ Limited
#6 |
Drives: FRS(sold), AP2, R35, FJC, ED9
you can look at the screen captures for the logging feature for the oft on their other cars. i have both and will use the oft for data logging and the torque app when i want to see fancier gauges. for 20 bucks the app and connector was a no brainer for me and the oft is the best upgrade ive done so far.
#7 |
Remember me?
Drives: BRZ Series.Blue
im using the app right now and honestly i wouldnt trust it as a data logging platform. A lot of the info seems inaccurate and more of a novelty. It said my peak hp number is 219whp
. it does vocally notify you when the car has reached normal operating temp though which is pretty useful.
| The Following 2 Users Say Thank You to glorydays For This Useful Post: | cjsporl (10-22-2013), Hanni_0176 (10-22-2013) |
#8 |
Thanks
Water and oil read out is worth the price in itself IMO
#9 | |
I figured the OFT would do the same thing, but I also saw that Torque logged 0-60 and 1/4 mile times, etc, which seemed useful. The fact that it actually announces when the oil reaches operating temps just sold me on it though. Thanks for that. |
| The Following User Says Thank You to Hanni_0176 For This Useful Post: | glorydays (10-22-2013) |
#10 |
if you're going to use torque, spend the money on a decent elm327. the cheap chinese knockoffs are so slow as to be marginally useful for monitoring, and completely useless for any sort of logging. they're not cheap, but you get what you pay for.
#11 | |
Drives: slow
If the HP calculations were any more than an extremely rough estimate based on the GVW you entered and the accelerometer readings, we wouldn't need Dyno's worth thousands of dollars. The other information regarding what the ECU sees (temps, o2, pressure, timing etc) will be as accurate as the sensor sending it. |
| The Following User Says Thank You to topazsparrow For This Useful Post: | glorydays (10-22-2013) |
| Open Flash Tablet Question | davidchoi | Software Tuning | 7 | 10-29-2013 02:58 PM |
| Open Flash v FA20/Visconti etc,? | cuddefred | Software Tuning | 15 | 10-09-2013 02:27 AM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 12:53 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 09:23 PM |
