Old 02-11-2014, 11:50 AM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
led cluster help
anyone know how to split the back part of the cluster to access the light bulbs? it seems sealed almost.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-11-2014, 11:51 AM   #2
sshole
You will need to remove the gauge needles, then lift off the gauge face.
You do not access the surface mounted LEDs from the back like you would a filament bulb on an older vehicle.
sshole is offline   Reply With Quote
Old 02-11-2014, 12:40 PM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
so they have to be soldiered in? hmm how do u remove needles without breaking the stem?
IG-Joey_Soul
Old 02-11-2014, 12:56 PM   #4
sshole
Yes, you will need to be proficient at soldering very small surface mounted components.
How do you remove the needles, indeed? I haven't tried my hand at this LED conversion myself, but I know that @Acree has and would probably have the most useful knowledge on this topic.
Old 02-11-2014, 01:33 PM   #5
xtuners
Drives: gt86
Could you pease scan your dials and share the scan with me?
Want to make a custom version of them. If you do the LED conversion right, you will get the first custom made dials
xtuners is offline   Reply With Quote
Old 02-11-2014, 02:22 PM   #6
Grip Ronin
The Mechanic
Grip Ronin's Avatar
scan my dials???
IG-Joey_Soul
Old 02-12-2014, 01:48 AM   #7
GaN-MaN
WA 86/BRZ Club
GaN-MaN's Avatar
Drives: Toyota 86 GT MT Sonic Blue
Needles just pop off. pull directly up, away from the gauge. Remember to mark it so you know the location of the needle for when you put it back.
The LED's are PLCC-2 LED's and are indeed soldered onto the main board of the dash cluster. Easy enough job just touchy i guess. I've done 3 so far.
2012 Toyota 86 Sonic Blue GT 6MT
GaN-MaN is offline   Reply With Quote
Old 02-12-2014, 09:06 AM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
cool. i had a bad exp with needles on my civic years ago, broke the stick off for my water temp lol
IG-Joey_Soul
Old 02-12-2014, 09:22 AM   #9
sshole
I'd like to see pictures/video of you popping off the needles. From what I've heard, you need to melt a piece of the needle from the shaft that holds it to the stepper motor before removal.
Old 02-12-2014, 12:00 PM   #10
onefitz
Drives: 13 GBS BRZ
Needles have always been twist counterclockwise and pull up for me. No melting or breaking of anything. Haven't done an FRS yet though.
onefitz is offline   Reply With Quote
Old 02-12-2014, 02:59 PM   #11
xtuners
Drives: gt86
scan my dials???
You will have to remove your dials anyway.
Why not put them on a PC scanner and make a clean scan ? )
Old 02-14-2014, 02:07 AM   #12
Blackrsx
Drives: Red FRS
I bought an extra set off eBay to do this. DIY post
Just found out our clusters may have data stored in it so will have to redo on my original cluster.
Blackrsx is offline   Reply With Quote
Old 02-14-2014, 12:29 PM   #13
Grip Ronin
The Mechanic
Grip Ronin's Avatar
cool i couldn't find a write up on this..
IG-Joey_Soul
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 04:02 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Cluster dome <---you need this! sav AFRICA 29 04-26-2013 04:38 AM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 11:09 AM
