Tracking / Autocross / HPDE / Drifting What these cars were built for! |
Drives: 2013 FRS
Alignment Suggestions
Currently, getting back into tracking my car and I'm looking for some good alignment settings (not too worried about tire wear)
The tracks I'll spend most of my time on are: Laguna Seca Sonoma Thunderhill Suspension & Aero Mods: Front Camber Bolts SPC Rear LCA's RCE Yellow Springs on Stock Shocks Perrin Front Sway Bar WRX Rear Sway Bar Velox Splitter w/ Endplates Velox Diffuser SARD LSR Wing TRD Canards Tires: 17x8.25 on 225/45/17 Hankook Ventus RS3 Preferably, I would like neutral steer with a crisp turn-in |
#2 |
Drives: 2015 Raven FRS
I would talk to Neal at the Racers Line. He lives up your way and runs the same tracks.
#3 |
Drives: '24 GR86
#4 |
Drives: 13' BRZ
I'm currently on -3.1F/-2.5R/0Toe which provides a very neutral feel - 255/40/17 RS3. Aligned by Eric@Elite Performance
Don't have experience with aero setups, but for non-aero, -3.0F/-2.0R/0Toe is a good starting point. Note: You will not be able to achieve -3.0F with stock strut and camber bolts alone. If you have slotted coils + camber bolts you'll max out around -3.0F. (This is not recommended; however, there are people who run this to stay in certain class for 86cup) Contact @Elite Performance or @The Racers Line and i'm sure they can help with further details. |
The Following User Says Thank You to Tenino For This Useful Post: | smg1138 (09-23-2016) |
#5 | |
Drives: 2013 BRZ Limited
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#6 | |
Drives: 2013 FRS
#7 |
Drives: 2013 FRS
#8 |
That's pretty good but not enough to dial out outer edge wear.
The Following User Says Thank You to zdr93523 For This Useful Post: | DarkSunrise (10-04-2016) |
#9 |
Drives: 2013 WRB BRZ 6MT
I think a good starting point for a primarily track driven car is to get as much in the front as you can and use about 0.5 less in the rear and then fine tune from there. For example, I personally went with -2.2f/-1.7r but this is a year round, daily driven street car and I felt this was a good balance to start off with and so far it's been fine. If it was a primarily track driven car though, I'd be shooting for -3f/-2.5r or so.
Looking for DD/track/autocross alignment suggestions. | Lynxis | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-12-2016 12:30 PM |
Camber/alignment for Eibach Prokit and when should I get alignment? | Meanderchap | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-01-2016 03:44 AM |
DIY alignment - quick way to set alignment while new suspension settles? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-11-2014 09:53 PM |
OP and FP suggestions | Sypher | Engine, Exhaust, Transmission | 12 | 03-06-2014 10:56 AM |
Any suggestions for my FRS? | kaikeng | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 08-04-2013 05:03 PM |
