Drives: 2017 Subaru BRZ
Not going into gears
Is it normal during cold weather that my car won't shift into gears?
Sent from my SM-G960W using Tapatalk |
#2 |
ProCrastinationConsultant
yep. i usually have to rev-match 1st while rolling to a stop at stop signs to get it to go in, or sit at a complete stop for 5 seconds to make it go in. 2nd will begrudgingly go in after that, 3rd/4th, i usually have no problems with
| The Following User Says Thank You to soundman98 For This Useful Post: | j_ros94 (11-29-2019) |
#3 |
Completely normal. Once warmed up it gets better.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | j_ros94 (11-29-2019) |
#4 |
Rust bucket enthusiast
Motul gear300 trans fluid fixed this for me. Even at -25f it shifts well initially. My ebrake on the other hand..
#5 | |
#6 |
Would being boosted having 330 whp affect that?
#7 |
braggarts weigh more.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Captain Snooze (12-05-2019), Ultramaroon (11-29-2019) |
#9 |
Unless the TOB is shot...
#10 |
#11 |
#12 |
Then you should be fine
#13 |
Famous Potatoes
Drives: '15 ultramarine
#14 |
Drives: 2017 BRZ w/PP
if you have trouble try n->2->1 i do that when i first start up getting out of where if live. once you get a little heat in it youll be fine
| The Following User Says Thank You to Breadman For This Useful Post: | Larphraulen (12-05-2019) |
| Even Gears | rns294 | Engine, Exhaust, Transmission | 1 | 04-12-2017 10:52 AM |
| Any one have 5.29 gears yet ? | ogie Oglethorpe | Engine, Exhaust, Transmission | 13 | 09-17-2016 12:17 PM |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 01:48 AM |
| 2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 06:09 PM |
