Old 12-31-2012, 03:46 PM   #1
Silp3
Silp3's Avatar
Fitment Issues
I purchased tires and wheels very cheaply for my FRS.
I was told the wheel lugs were 5 x 100 and the wheels where previously installed on a Pontiac Vibe also known as the Toyota Matrix.
I attempted to fit the wheels on my FRS and my Forester and both times, they did not fit.
I am getting frustrated because I measured from the center of the wheel lug hole to the center of another wheel lug hole and it measured 4 5/16 inches. Converting that to mm I get a 5 x 100 lug pattern.
Before I make a fool of myself and call this person back, I would like to be properly educated.
From the best of my knowledge and the help of Tirerack, I have concluded that Pontiac Vibes do indeed have 5 x 100 mm lugs. Only problem is, I cannot prove that these were used on a Pontiac Vibe.
Would offset, lug-centric or hub-centric play a part in this? Should I be rotating the wheels so different lug holes match with the lug bolts?
I feel like I'm an amateur tire installer when I've gone through a dozen wheels and tires on my previous cars and never had this issue.
My conclusion is the wheels are indeed falsely advertised and that the seller will have to reimburse my payment.
Silp3 is offline   Reply With Quote
Old 12-31-2012, 03:58 PM   #2
camelflage
Drives: pinto power
the bolt pattern is sometimes stamped into the back of one of the spokes / hub area. or on a sticker in the barrel.
also, how do they not fit? if the studs line up but it wont sit flush against the rotor, then it might be that the hub bore is too small..
camelflage is offline   Reply With Quote
Old 12-31-2012, 04:06 PM   #3
OrbitalEllipses
Drives: Attitude
Their hub bore should be 57.1 according to the internets. We're 56.15 so theoretically it should fit. It always takes me a few seconds to finagle the bolt holes onto the studs.
Old 12-31-2012, 04:25 PM   #4
_F-R-S_
Drives: 13 whiteout scion frs
Anything that was on a pontiac vibr should not go on the frs.. I mean even the car is rejecting them..
_F-R-S_ is offline   Reply With Quote
The Following User Says Thank You to _F-R-S_ For This Useful Post:
Sportsguy83 (01-01-2013)
Old 12-31-2012, 04:50 PM   #5
Silp3
Silp3's Avatar
Lol they're steel wheels and snow tires. The lugs themselves are not fitting
Old 12-31-2012, 04:58 PM   #6
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
the lugs are probably a different thread pitch, the wheels fit over the studs right?
Old 12-31-2012, 05:10 PM   #7
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
My research says that they are the same thread and size as a vibe too, so unless you have too small of a wheel (15" rims or some 16" rims) and it is hitting the brake, they sold you the wrong stuff.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
Old 12-31-2012, 05:50 PM   #8
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
It sounds like the lug nuts are not fitting. Our lug nuts are a 12x1.25 Toyotas are 12x1.5 pitch. You need different lug nuts.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-31-2012, 08:20 PM   #9
OrbitalEllipses
Drives: Attitude
Subaru/Nissan lug thread pitch is 12x1.25, correct.
Old 01-01-2013, 12:42 PM   #10
RazorHawk
Yes, my mistake, however, I believe the issue the OP is having is that the actual wheel will not go onto the studs, apparently due to spacing issues, or, as I posited above, possibly backspacing or clearance issues. I do not think the OP has even gotten to the point where lugnuts could go on.
I think that the OP needs to take some photos of the front and back of the wheel, maybe with a tape laid across for reference, as well as provide the size of the rim.
That way, we can better evaluate where the issue may lie. If it is a 17, 18, 19, etc, the issue I had mentioned above (brake rotor clearance) is an obvious no, and we need to look elsewhere. If it is a Stock size replacement, that appears to be 16x6.5, 40 offset, which would probably be fine, however the vibe WILL fit 15 in rims, while I am fairly certain that there is no 15 in rim out there that will fit an FRS, so that could be the issue.
5AD Spoiler
Old 01-01-2013, 12:49 PM   #11
OrbitalEllipses
Drives: Attitude
Stock Vibe wheel is 14"x6" IIRC. The smallest wheels you'll fit on our platform will be 15" rally wheels.
Old 01-01-2013, 01:33 PM   #12
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
57.1 bore will fit, however a 57.1 bore will be lug centric and not bore centric.
Here is some reference:
http://www.ft86club.com/forums/showp...&postcount=135
I have read about a 15" wheel that I believe does fit, search the wheel section of this forum, but it is a very particular one, so probably not that easy to find.
smbrm is offline   Reply With Quote
Old 01-01-2013, 03:04 PM   #13
Silp3
Silp3's Avatar
I thank you all for the responses. The wheels are 16 x 6.5 the tires are General Altimax Artic and have been sized as 205/55/16.
I will take pictures shortly and will post with tape for reference. The wheels will not actually go over the studs.
Old 01-01-2013, 05:07 PM   #14
gmookher
why..
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 163 04-06-2023 01:55 AM
Is this what they mean by panel fitment issues? ahquit Issues | Warranty | Recalls / TSB 7 08-21-2012 04:19 PM
JDM clear sidemarker fitment issues D1cker Cosmetic Modification (Interior/Exterior/Lighting) 6 07-27-2012 04:44 PM
Interior Fitment? PecanSandies BRZ First-Gen (2012+) — General Topics 2 06-10-2012 08:21 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 07:33 PM
