Drives: 2013 BRZ Limited 6MT
E85 MPG
I know some are curious of what kind of mpg they'll get if they change over to E85 full time. I'll start with the two tanks I've run through to this point, and hopefully others can add info for other conditions / driving styles to round it out.
First tank 18 MPG Second Tank 17.5 MPG Thats 70-72% of my average pumpgas MPG For reference I was getting 25 MPG on 93 pumpgas with the Visconti tune, and slightly lower than that on the stock flash. I know that a lot of people will see higher numbers, but will have had higher numbers than I did on pumpgas. I do not see much in the way of open highway miles and am pretty liberal with the throttle. Also, these are hard numbers from odo / receipts. The dash gauge is off far worse with E85 than pumpgas For reference, here is the E85 tune info http://www.ft86club.com/forums/showthread.php?t=15753 Last edited by DSTL; 09-10-2012 at 01:03 PM. |
#2 |
Automotive Enthusiast
Did you need to modify the engine at all to accommodate E85 (ie. injectors, fuel lines, etc.)?
Obviously, I haven't used E85 in my FR-S yet, but if it is cheaper to run per mile in comparison to 93 octane, I'll probably switch over. |
#3 |
All stock aside from tune. Fuel will cost you more, but performance increase is dramatic.
#4 | |
Drives: truck and old car
#5 |
Here are my averages:
Stock Tune: 28-29 MPG (mixed city/hwy) 93 Visconti Tune: 31-33 MPG (mixed) e85 Tune: 25-26 MPG (mixed, but beat it quite a bit) |
#6 |
#7 |
Drives: 2013 Scion Frs(Scarlet)
25-26 sounds good to me lol...to you and DSTL, is there a big difference between the 93 tune and e85 tune? Or is it just an extra kick?
#8 | |
Edit: 2012 EPA Flex Fuel data for comparison. Pretty inline with results here http://www.fueleconomy.gov/feg/byfuel/FFV2012.shtml Just got home and did the quick math on this. In my case at least, with 93 at $4.09 and E85 at $3.39, the annual cost difference at 15,000 miles is $450 more to run E85. I'll gladly pay that for 35HP over stock (20ish over pumpgas tune) Last edited by DSTL; 09-10-2012 at 08:39 PM. |
