Old 11-07-2015, 08:01 AM   #1
ztan
Drives: Toyota 86
Knock Sensor Control Logic
Following @Td-d's work on the ROMraider forums here:
http://www.romraider.com/forum/viewt...hp?f=40&t=8615
I had a look at the A01G ROM with ScoobyROM.
Knock sensor calibration table was easy to find using Td-d's ScoobyROM method, unpicking the knock control logic is quite difficult. There is also a table that looks like it uses FLKC table offset as an input - possibly a threshold. All highly experimental.
Welcome any input into deciphering the knock logic.
Code:
    <table name="Knock Sensor Calibration" storageaddress="11DF48">
      <table type="Y Axis" storageaddress="11DDEC" />
    </table>
    <table name="Knock Threshold" storageaddress="11612C">
      <table type="Y Axis" storageaddress="1160A0" />
    </table>
    <table type="2D" name="Knock Sensor Calibration" category="Ignition Timing - Knock Control" storagetype="uint16" endian="big" sizey="87" userlevel="4">
      <scaling units="ECU value" expression="x-32" to_byte="x+32" format="0" fineincrement=".5" coarseincrement="10" />
      <table type="Y Axis" name="Knock Sensor" storagetype="float" endian="little">
        <scaling units="volts" expression="x" to_byte="x" format="0.0000" fineincrement=".01" coarseincrement=".1" />
      </table>
      <description>Knock sensor calibration</description>
    </table>
    <table type="2D" name="Knock Threshold" category="Ignition Timing - Knock Control" storagetype="float" endian="little" sizey="35" userlevel="5">
      <scaling units="ECU value" expression="x" to_byte="x" format="0.0000" fineincrement=".5" coarseincrement="10" />
      <table type="Y Axis" name="FLKC Offset" storagetype="float" endian="little">
        <scaling units="Offset" expression="x" to_byte="x" format="0" fineincrement="1" coarseincrement="1" />
      </table>
      <description>?? Knock threshold by FLKC offset </description>
    </table>
ztan is offline   Reply With Quote
The Following 3 Users Say Thank You to ztan For This Useful Post:
elBarto (11-07-2015), Kodename47 (11-07-2015), solidONE (11-07-2015)
Old 11-07-2015, 12:43 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The stuff that would be really handy to have are the per cylinder thredholds with the appropriate logging parameters.
I doubt that anyone will change the sensor cal.
How does the lower one work?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-07-2015, 01:19 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
Just FYI (stumbled across this while learning romraider):
http://www.romraider.com/forum/topic1840.html
http://www.romraider.com/RomRaider/H...ndKnockControl
http://forums.nasioc.com/forums/show....php?t=1433675
I apologize if you have already found this.
Old 11-07-2015, 04:54 PM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Nice! (subbed)
Intent > Content
Old 11-07-2015, 06:38 PM   #5
ztan
Drives: Toyota 86
No real idea, but the value that gets passed to the 2D table is the FLKC cell offset - this reads 0-4 in the first RPM range as load increases, then 5-9 in the next RPM range... 35 values in all for 5 load ranges and 7 RPM ranges.
I played around with reformatting the table to the following, which makes me suspect that this is a table defining knock threshold or sensitivity per FLKC cell. The logic is very complex and I am nowhere close to unravelling it:
Code:
    <table type="3D" name="Knock Threshold" category="Ignition Timing - Knock Control" storagetype="float" endian="little" sizex="5" sizey="7" userlevel="4">
      <scaling units="ECU value" expression="x" to_byte="x" format="0.000" fineincrement=".2" coarseincrement="1" />
      <table type="Static X Axis" name="" sizex="5">
        <data>FLKC Load Range 1</data>
        <data>FLKC Load Range 2</data>
        <data>FLKC Load Range 3</data>
        <data>FLKC Load Range 4</data>
        <data>FLKC Load Range 5</data>
      </table>
      <table type="Static Y Axis" name="" sizey="7">
        <data>FLKC RPM Range 1</data>
        <data>FLKC RPM Range 2</data>
        <data>FLKC RPM Range 3</data>
        <data>FLKC RPM Range 4</data>
        <data>FLKC RPM Range 5</data>
        <data>FLKC RPM Range 6</data>
        <data>FLKC RPM Range 7</data>
      </table>
    </table>
Old 11-08-2015, 12:39 AM   #6
steve99
Drives: FT86
could it be something like this table in romraider learning view, buy i suppose it would be in ram as its learned values ?
Old 04-15-2024, 12:14 AM   #7
Compelica
Compelica's Avatar
Drives: 86 GT
Hi @callisto - any idea if these FLKC values are stored anywhere in RAM?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 04-15-2024, 12:18 AM   #8
callisto
Drives: 2019 Subaru BRZ
That’s an excellent question, it’ll take a bit to find out but I’m certain they’re in there, that tool is reading them. (Note to self, read every ztan post.)
callisto is online now   Reply With Quote
Old 04-15-2024, 03:21 AM   #9
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks. Have not used the Learning View before, it could possibly just be logging values across different load / RPM ranges as the car is driven.
Never thought of this, but not sure how IAM/FLKC persists when the car is turned off... does that mean the ECU and the RAM is kept in a low power state? @AussieBRZ ?
@ztan has a lot at his disposal as well, it was him who worked on the pre-facelift flex-fuel tunes I believe.
Old 07-04-2024, 04:29 PM   #10
callisto
Aha, I recognize that memory address, I've been looking into this previously.
S10C/FFF815E0, K00G/FFF810B4 - there are 35 pairs of (A, B) floats, stored in the order A1 B1 A2 B2 A3 B3 etc. The FLKC values you see in datalogs derive from the A-side.
Yes, the ECU RAM is kept alive by the battery, which is why pulling the battery or fuse resets the ECU. There's an EEPROM storing VVT learned values, which I want to look into more someday.
(Also: S10C/FFF816F8 is the start of a series of unsigned shorts that is storing what is likely FLKC counters of some sort. That's where my research left off, so I don't have any details for this yet.)
The Following User Says Thank You to callisto For This Useful Post:
Compelica (07-05-2024)
Secondary O2 sensor needed for Cruise control? DJCarbine Engine, Exhaust, Transmission 31 04-10-2015 09:49 PM
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 10:29 AM
Active Knock sensor Fat Spider Engine, Exhaust, Transmission 13 07-14-2013 09:37 PM
