Old 08-21-2012, 09:50 AM   #1
frsinpa
Drives: fr-s!
edited
edited..
frsinpa is offline
Old 08-21-2012, 09:53 AM   #2
luxmn
First FR-S
Drives: Whiteout MT FRS
I think that's the tire pressure monitoring light. I think you may have a slow leak.
luxmn is offline
Old 08-21-2012, 09:54 AM   #3
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
That is your TPMS (Tire pressure Monitoring System) light.
No cause for major alarm. Just means the system senses one of your wheels is spinning at a rate different from the other tire. What normally causes a difference in Wheel RPM is a tire with a low amount of air. Excessive amounts of air in one tire can cause this too.
Just check the air in all your tires. 35 PSI if on OEM Michelins. Wouldn't hurt to check to make sure you don't have a nail or screw embedded in one of your tires causing a slow leak.
Once you reset the air, you need to drive it for a few miles for the light to turn off.
F1point4 is offline
Old 08-21-2012, 09:54 AM   #4
Racelex
Drives: Impreza GC8
Looks like a tire pressure warning light, but don't quote me on that. My cars are not this high tech.
Racelex is offline
Old 08-21-2012, 09:59 AM   #5
ayau
Drives: Some rust bucket
Check your tire pressure.
ayau is offline
Old 08-21-2012, 09:59 AM   #6
frsinpa
Drives: fr-s!
Ahhh - thanks guys! For some reason, several sites on the internet said that it was a traction control system issue. Phew.
frsinpa is offline
Old 08-21-2012, 10:10 AM   #7
CoBrA788
CoBrA788's Avatar
Drives: 86 Manual, white pearl
^^^agreed, had this on my BMW, if you can't visually spot the problem tire(meaning by the time you check your tires one of them could be completely flat), you could have a slow puncture.
If you've pumped the tires up and the light goes off, but comes back on later have the problem tire inspected.
CoBrA788 is offline
Old 08-21-2012, 10:19 AM   #8
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
This is correct about the TPMS.
Don't know if the part about the car sensing one wheel spinning more than another BUT each wheel has a pressure sensor in it linked to the car's monitoring system. Your manual will tell you about this and how to reset it once you've corrected the issue.
I carry a tire pressure gauge in my glove box and I recommended everyone do the same but you can also check and fill your tires at most gas stations. Don't know about everywhere else but in CT it is free even though most machines are coin operated. The gas station attendants activate them remotely or give you tokens to use the machine.
Do not overfill. As mentioned above, 35 PSI is a good target.
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline
Old 08-21-2012, 10:21 AM   #9
HunterGreene
Hail Magnet
HunterGreene's Avatar
Funny, I thought that it was the "Car is about to take a dump" light.
HunterGreene is offline
Old 08-21-2012, 10:22 AM   #10
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Don't people ever look into their owner's manual anymore? I guess if there is ever an issue just ask the internetz.
And from the look of it it's probably low air in your tires. Check the PSI on all 4.
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
Old 08-21-2012, 10:24 AM   #11
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
This happened to me yesterday after a long cold rain leaving work, having worked for DTC for 15 years I head over to have the car lifted and checked for nails, no nails, but the tires were all at 32 Psi from the dealer. So I jacked them to 40 since the max air on the Michelin Primacy max is 44.
I figure with winter coming I would just trick the TPM and it reset no less than 100 meters from leaving the store.
The rides not so bad at 40 Psi, and the roads here are central America lousy. If the light comes back on after a day or two, I'll have them take off the tire and dunk it in the tank.
DTC will sell you the Non Prorated Road hazard on the tires, it's expensive but so are the stock rubbers, 185-215 per depending on where you source them from. so for close to the cost for one you cover all four from just about anything that the road can put in their path.
Safe Travels.
Spartan65
Spartan65 is offline
Old 08-21-2012, 10:25 AM   #12
SilentMike
Drives: 2013 FR-S 6MT Asphalt
The TPMS light in my Civic looks just like that. Must be a universal symbol. To parrot what the others have said, check your tire pressure.
SilentMike is offline
Old 08-21-2012, 10:27 AM   #13
Wepeel
Drives: '13 BRZ Ltd
Good possibility that the recent cold(er) weather is resulting in low enough tire pressures to set off the light.
Wepeel is offline
Old 08-21-2012, 10:48 AM   #14
frsinpa
Drives: fr-s!
My front right tire had 29 PSI and I pumped it back up to 35.. problem solved.
I totally blame Chacha.com for freaking me out with the following (and completely wrong) article, haha.
http://www.chacha.com/question/what-...on-in-my-scion
frsinpa is offline
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 08:08 PM
Early morning fun run 6/10? blalor New England 8 06-11-2012 11:09 AM
Back of BRZ LED Driving Light Picture JRitt Cosmetic Modification (Interior/Exterior/Lighting) 6 06-08-2012 09:51 AM
Got a call from a Toyota Rep this morning... Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 36 06-03-2012 12:10 AM
Picked up my Raven 6MT FRS this morning :) yamaha16bw Scion FR-S / Toyota 86 GT86 General Forum 15 05-31-2012 08:02 AM
