Drives: 2013 FRS
Engine Knock or Vacuum Pump?
This is a 2013 FRS Automatic, 103k miles. My engine is currently making a tapping/knocking sound, the sound is not there when the car is cold; however, when warmed up the sound is heard. My biggest fear was engine knock but after browsing other forum posts I've seen that the automatic transmissions have an issue with vacuum pumps that sounds similar. I have attached videos of the sound below, it is primarily heard on the passenger side of the vehicle. What does this sound like? Engine Knock, Vacuum Pump, or other?
| The Following User Says Thank You to Dazzo For This Useful Post: | humfrz (08-23-2021) |
#2 |
I can't tell anything from the videos.
I suggest get in closer to the vacuum pump and post a listen. |
#3 |
Drives: Halo 86, '19
Sounds like some weird metallic clutter that happens either when you throttle too hard at low RPM or around the 4200 RPM mark. The deeper grunts sound like low RPM lugging to me.
| Tags |
| automatic, knock, noise, tap, vacuum pump |
| Brief engine knock/cold engine/first couple accelerations@2.8-3krpm | Reyanth | Issues | Warranty | Recalls / TSB | 5 | 11-15-2020 02:32 PM |
| DIY - Finding a vacuum leak (Cigar/Pump method) | BigTuna | DIY (Do-It-Yourself) Guides | 0 | 08-12-2019 10:13 AM |
| Vacuum Pump? | febrz | Issues | Warranty | Recalls / TSB | 0 | 04-13-2018 04:08 PM |
| Engine knock | Zentec | Engine, Exhaust, Transmission | 22 | 09-05-2017 03:46 PM |
| Vacuum pump oil | USMCgetsome | Engine, Exhaust, Transmission | 4 | 12-10-2016 08:16 AM |
